ECU question....
Old Oct 30, 2006 | 05:50 AM
NA JDM GSR's Avatar
Default ECU question....
i ordered a phearable.net chipped ecu...when i get it do i have to get it tuned by like crome or hondata or can i juss connect my chipped one to the engine harness...
Old Oct 30, 2006 | 06:00 AM
tweekerz's Avatar
Default Re: ECU question.... (NA JDM GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA JDM GSR &raquo;</TD></TR><TR><TD CLASS="quote">i ordered a phearable.net chipped ecu...when i get it do i have to get it tuned by like crome or hondata or can i juss connect my chipped one to the engine harness...</TD></TR></TABLE>
You have to have a program burned to a chip that plugs into the socketed ecu. You can use Crome or Uberdata, etc. The basemap needs to be specific for your needs and setup ie boost, n/a.
Old Oct 30, 2006 | 06:02 AM
NA JDM GSR's Avatar
Default Re: ECU question.... (tweekerz)
i think phearable.net does it...so i should b good
Old Oct 30, 2006 | 06:03 AM
NA JDM GSR's Avatar
Phearable.net uses basemaps which are only from actual vehicles which have been tuned by phearable.net using a wideband oxygen sensor and a dynojet. This is what separates phearable.net from other modified ecu distributors.
Old Oct 30, 2006 | 06:14 AM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA JDM GSR &raquo;</TD></TR><TR><TD CLASS="quote">Phearable.net uses basemaps which are only from actual vehicles which have been tuned by phearable.net using a wideband oxygen sensor and a dynojet. This is what separates phearable.net from other modified ecu distributors.
Exactly. Just get the basemap of your choice from phearable.net. Only trick is finding an available tuner in your area.
Old Oct 30, 2006 | 07:32 AM
NA JDM GSR's Avatar
how can i get a basemap??? does it come with the ecu?? sry im a noob at ecu's
Old Oct 30, 2006 | 07:42 AM
F20Cteg's Avatar
Basemaps are just basemaps. It doesn't matter if they are actually from a tuned motor. Every motor is different. Basemaps like that usually only work well with mildly modified motors.
Basemaps
Tuned
Don't ever believe that basemaps are okay. It doesn't matter who made it.
Old Oct 30, 2006 | 07:52 AM
NA JDM GSR's Avatar
Default Re: ECU question.... (F20Cteg)
so what exactly is tuning??
Old Oct 30, 2006 | 07:54 AM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA JDM GSR &raquo;</TD></TR><TR><TD CLASS="quote">how can i get a basemap??? does it come with the ecu?? sry im a noob at ecu's</TD></TR></TABLE>
Did you already order the ecu? I think you can specify that when you order. If you already ordered, contact a local tuner when you have your ecu and tell them about your setup. He'll burn you a basemap.
Old Oct 30, 2006 | 07:55 AM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg &raquo;</TD></TR><TR><TD CLASS="quote">
Yes. Basemap will get your car running until you get tuned. You dont want to go into WOT or boost until your tuned.
Old Oct 30, 2006 | 08:06 AM
NA JDM GSR's Avatar
i didnt order it yet..i will today...phearable.net wants me to write down my motor setup...im doin NA...
Old Oct 30, 2006 | 08:40 AM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA JDM GSR &raquo;</TD></TR><TR><TD CLASS="quote">i ordered a phearable.net chipped ecu...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA JDM GSR &raquo;</TD></TR><TR><TD CLASS="quote">i didnt order it yet..i will today...phearable.net wants me to write down my motor setup...im doin NA...</TD></TR></TABLE>
Interesting......however they want you to write down your ENTIRE setup because they have base maps from cars with bolt-ons (I/H/E) to cars with mild builds (I/H/E, 11:1 compression + stage I cams) to cars that have 15:1 compression, stage III cams, P&P work, and stroked/bored to 2.2L
Old Oct 30, 2006 | 08:44 AM
NA JDM GSR's Avatar
Default Re: ECU question.... (95 integra)
o so it will come with a basemap??
Old Oct 30, 2006 | 09:18 AM
95 integra's Avatar
Yes, but isnt this what the 1-800 # is for?
Old Oct 30, 2006 | 09:25 AM
iH8RICERZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA JDM GSR &raquo;</TD></TR><TR><TD CLASS="quote">o so it will come with a basemap??</TD></TR></TABLE>
why don't you ask questions before you buy something. PM MTBER and you can ask him directly....
Old Oct 30, 2006 | 11:01 AM
NA JDM GSR's Avatar
Default Re: ECU question.... (iH8RICERZ)
whos that
Old Oct 30, 2006 | 11:15 AM
95 integra's Avatar
Because hes the owner of phearable.net
Old Oct 30, 2006 | 12:25 PM
Sack Master's Avatar
You really should get these answers from those guys. They'll tell you what you need to do to make it work. And most mail order tunes work very well as long as you are 100% honest with what you are doing.
Andy Hatchback
Feb 12, 2008 10:33 AM
JDM91EF2
22
Dec 23, 2006 02:38 PM
soeurm
Apr 27, 2006 04:46 AM
jdmeg9
Mar 19, 2006 11:37 AM
StreetRacnGsR
May 11, 2003 02:18 PM
