ecu question
Old Oct 25, 2005 | 10:10 AM
redb16integra's Avatar
Default ecu question
how do u reset the ecu on a 91 integr with a b16
Old Oct 25, 2005 | 10:12 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: ecu question (redb16integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redb16integra &raquo;</TD></TR><TR><TD CLASS="quote">how do u reset the ecu on a 91 integr with a b16
Well, if you have a B16, then you just pull the main 15amp ECU fuse for a few minutes. You can also disconnect your negative battery terminal for a few minutes.
This will only "reset" your ECU. Personally, I have never found a reason to do this. If you want to "clear your codes", you will need some sort of OBD tool/scanner. Some emissions related codes will remain until they are cleared.
standbackimapro
Sep 7, 2007 10:35 AM
so lazy
Jul 7, 2007 01:28 PM
IgnitionZ05
Jun 13, 2007 10:49 PM
i20ar
Jul 19, 2004 07:42 AM
Fatty_1775
Aug 5, 2003 05:37 AM
