ecu problems pleases help
Old Oct 17, 2009 | 03:36 PM
negro_1087_delta's Avatar
Default ecu problems pleases help
hey wats up yall i bought this ecu that soposedly was chipped and i was driving it but it will not go past 6k the ecu is a p72 obd2a and for now im runnning an ls motor is the ecu bad or is it a safety mechanism that i am sopose to use in a v tech motor thanks in advance
Old Oct 17, 2009 | 03:39 PM
vladd's Avatar
Default Re: ecu problems pleases help
why are you using a vtec ecu on a non-vtec motor? what kind of chip does it have? is it one of those ebay chips, or socket/chip type of setup that's been tuned? your cel should be on, and it might be putting the ecu in limp mode, which would give you a lower redline.
Old Oct 17, 2009 | 03:40 PM
ek-g6's Avatar
I think it because you dont have a vtec motor, but could also be ignition coil also.
Old Oct 17, 2009 | 03:49 PM
i am using this ecu because i want to go ls v , the chip is soposedly a skunk 2 , the tune soposedly an all motor stage 3 and if its in limp mode how do i fix it
Old Oct 17, 2009 | 06:34 PM
DAintegraGSR's Avatar
id recomend using a stock ecu or a non vtec ecu untill you have a motor that demands such mods. sorry just my 0.02
Old Oct 17, 2009 | 06:37 PM
vladd's Avatar
i'd definitely switch back to a stock ecu. obd2 ecus can't be chipped, so either the ecu you're using isn't obd2 or it's not chipped. once you're ready to tune your motor get a obd1 ecu and socket/chip it.
hung_kuen
12
Nov 20, 2007 08:26 PM
Lil BAiLeY IV
Jan 20, 2006 10:48 PM
Turbo Powa
Apr 17, 2002 04:01 PM
