Ecu Crap
Old Mar 18, 2005 | 10:24 AM
VTECisSeXY's Avatar
*insert here*
Default Ecu Crap
So i get in my car and find that my Manitence Required (not the check engine light) light is flashing. doh. It flashed 10 short times. 10 IAT - intake air temperature sensor correct? I just wanted to make sure on this... my Check engine light <U>WASNT</U> blinking.
Also, when I jumped the service indicator my abs code flashed a 4 8 wheel sensor LR. Now when the car is started the ABS light <U>isnt </U>on. Any ideas?
Normally i wouldnt have posted this but it seems kinda odd. maybe im just a noob
Old Mar 18, 2005 | 11:10 AM
purplegsr's Avatar
Default Re: Ecu Crap (VTECisSeXY)
Maintenance Required Light should not be confused with your CEL. The Maint light comes on every 7500 miles exactly, to remind you to change your oil and do the preset service schedule. In order to reset it, just grope around under the dash in front of your right knee. You should feel a button (square) underneath that cover panel - press it, hold it down, and turn your ignition to Access/On, I can't remember. Keep holding it, and the light will go off.
Old Mar 18, 2005 | 11:13 AM
VTECisSeXY's Avatar
*insert here*
Default Re: Ecu Crap (purplegsr (Exospeed))
thank you very much. If you were closer I woud buy you a beer
Old Mar 18, 2005 | 11:15 AM
purplegsr's Avatar
Haha, no problem.
1slowcrx
Dec 6, 2011 04:51 AM
PIC Performance
Jun 12, 2006 10:37 PM
jizzer671
Nov 30, 2005 09:31 AM
huepowered
Jul 6, 2004 06:16 AM
Red2001GSR
Feb 19, 2002 10:28 PM
