ecu codes
Old Feb 27, 2006 | 03:54 PM
b18c4dr's Avatar
Default ecu codes
first timer working on import check engine light on hear you can jump the codes i just dont know how where to put the wire to get codes heard very easy
search on how no threads on how just on what codes are
thank for any help
Old Feb 27, 2006 | 03:55 PM
b18c4dr's Avatar
Default Re: ecu codes (b18c4dr)
96 gsr sorry
Old Feb 27, 2006 | 04:00 PM
tallyturbo's Avatar
by your ecu there should be a blue plug that has two wires coming out of it. jump that plug by taking a wire and putting each end in one of the plugs. then turn you car to the on posistion and it should start blinking. the long blinks=10 the short=1. so if it looks like this !...!...!...!...!.!.! that would be code 43. once you get the code come on here and search for it.
Old Feb 27, 2006 | 04:01 PM
b18c4dr's Avatar
Old Feb 27, 2006 | 04:04 PM
b18c4dr's Avatar
thank you got the haynes book just didnt know the wire part really big help ill be back here soon
Old Feb 27, 2006 | 04:08 PM
tallyturbo's Avatar
one of the wires coming out of the plug is brown i know that for sure. come back with the code and maybe ill help you out.
Old Feb 27, 2006 | 04:12 PM
iH8RICERZ's Avatar
Default Re: ecu codes (tallyturbo)
go to the civic forum and look at one of the first 5 posts...they made the ecu code topic a sticky. Has all the codes, how to jump your ecu to pull the codes, ecu pin outs, etc.
Old Feb 28, 2006 | 08:22 AM
b18c4dr's Avatar
Default Re: ecu codes (iH8RICERZ)
thanks for schooling me ill update after water goes away
Old Feb 28, 2006 | 08:29 AM
b18c4dr's Avatar
thanks explains everything
Old Feb 28, 2006 | 09:59 AM
b18c4dr's Avatar
codes is (92) i think 9 long blinks and 2 quick blink
cold air intake can throw this sensor off
evap sensor? what is the fix for this code thumbup:
Old Feb 28, 2006 | 10:31 AM
tallyturbo's Avatar
i dont know the fix but was that the only code it was throwing? in other words when you got the code when it stopped blinking did the code that start blinking next the same?
Old Feb 28, 2006 | 11:10 AM
b18c4dr's Avatar
repeats the same code over and over thanks
Old Feb 28, 2006 | 11:23 AM
b18c4dr's Avatar
purge valve solinoid 152.00 dealer thanks for your input turbo
Old Mar 1, 2006 | 03:09 PM
tallyturbo's Avatar
no problem. i hope you fix your car.
JDMlyfestyle
588
Nov 3, 2022 12:37 PM
JDMlyfestyle
18
Apr 29, 2021 01:09 AM
Daniel-sanB1
10
Jan 5, 2006 10:10 PM
Ej1_coupe
Apr 30, 2004 12:55 PM
93EH6
Jan 30, 2003 09:11 PM
