Ebrake light question....
Well my ebrake light doesnt turn off while I am driving... I think I can here the brakes in the rear grabbing but its only on the right side. Does this mean I need to adjust my ebrake cable under the armrest? I tried checking the brake fluid but its fine! Are there any more explinations for this?
I have the same problem every once and a while, but usually only when its real cold out. I was going to try to adjust the ebrake but it went away sooo yea any more insight on this would be nice.
BUMP from the dead,
well i just did disc conversion and now have the same problem as you. the damn "brake" light won't turn off when i put the ebrake down.
have you figured out this problem?
Sometimes the sensor on the master cly. for brake fluid level gets stuck, and more likely in the morning. Clean it up if it doesnt work check for an open circuit in the E-brake SW.
well its a new MC that i put in... i'll check the cap, been searching at other threads and seems that the floater can get stuck or bad cap? gonna try this out in the morning.
