Ebrake acting up
Old Feb 11, 2008 | 10:16 AM
vietxdragon's Avatar
Default Ebrake acting up
hey guys, my ebrake feels weird out of no where, likes its very sloppy and loose until i pull the ebrake more than half way up, its works and all but why does it feel like this? its really bothering me
Old Feb 11, 2008 | 10:22 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Ebrake acting up (vietxdragon)
check to see if the little vinyl flap that covers the hole under the ebrake handle is catching on the teeth of the handle's gear....
you should also pull your center console out and inspect the cables at the ebrake as well
hatchling37's Avatar
Jack that ***** up and check out the return spring on your calipers. If they're sound, maybe you just need to adjust your cables underneath the center console.
Old Feb 11, 2008 | 10:55 AM
well it was working fine the night before, then following day i go out and noticed it was sloppy, im not sure if it could be becuz its winter and its been freezing out but i'll take a look at it. What exactly am i looking for on the return spring? what do i check?
Old Feb 11, 2008 | 02:44 PM
B18IntegraLS's Avatar
Reject Pimp
Cable probably went out check it under center console bro.
Old Feb 11, 2008 | 03:35 PM
man it soo cold, if it went out would my ebrake still be able to work?
Old Feb 13, 2008 | 06:52 PM
lmike6453's Avatar
try tightening it from the under the armrest
Otherguy
Honda S2000
16
Mar 20, 2007 06:06 PM
MestizoRacer310
Jul 20, 2006 04:11 PM
vti-R
Feb 28, 2002 04:20 AM
yellow blur
Feb 16, 2002 12:34 PM
