E85 Question
Old Jan 3, 2010 | 07:09 PM
heeltoehonda's Avatar
Default E85 Question
Not sure where this topic should be, but here it goes..
Do E85 tuned engines also run premium, regular, and unleaded gasoline?
If so, does the gas milage increase when runing the 3 other types of gas other than E85?
Old Jan 3, 2010 | 07:42 PM
GagnarTheUnruly's Avatar
Default Re: E85 Question
I heard that making an engine E85 capable has as much to do with solvent-proofing the fuel system as tuning the engine to run the different fuel. I think typical flex-fuel type cars run best on gasoline and 'get by' on ethanol, and they get better fuel economy on gas than on E85. Engines designed specifically for ethanol will be higher compression and won't run well on gas, particularly low octane gas.
I bet a lot has to do with how the engineer designed the engine (i.e. with what compression) and whether the ECU can respond well to the type of fuel that is present.
Old Jan 3, 2010 | 08:29 PM
Thanks for the imput
Old Jan 4, 2010 | 04:21 AM
Dogginator's Avatar
Daisy... Daisy...
If an engine is tuned for E85, it would run horribly rich with normal gasoline. You can only run E85 in an engine tuned for E85 unless you have an adaptive fuel management system that can determine the ethanol content of the fuel.
Old Jan 4, 2010 | 07:37 AM
That makes a lot of sense.
Someone else told me otherwise, but I had to make sure
Thanks
Donkey85
May 9, 2008 08:30 PM
99hondacura
Jul 30, 2006 03:09 AM
VTteg
Feb 16, 2006 12:06 PM
Cottonwoodz
Sep 19, 2002 11:59 AM
slowcivic
Sep 5, 2002 02:40 PM
