DYNO PROBLEMS
Old Apr 7, 2002 | 01:09 PM
Audipwr1's Avatar
Default DYNO PROBLEMS
I dynoed my car last week
only got 137.8 hp (SAE corected) on a 1996 GSR with CAI and rs*r catback exhaust
car is going in for timing belt, waterpump and valve adjustment
what else should i do?
Old Apr 7, 2002 | 01:14 PM
Erik_Pb_Foot's Avatar
New User
Default Re: DYNO PROBLEMS (Audipwr1)
Depending on what mods you plan on in the future, how about an aftermarket oil pump gear?
Old Apr 7, 2002 | 01:39 PM
Audipwr1's Avatar
Default Re: DYNO PROBLEMS (Pb_Foot)
that wouldnt be the problem with super lower than average dyno numbers
Old Apr 7, 2002 | 02:39 PM
ForestCrunk's Avatar
That is at the wheels? right. What numbers were you expecting?
Old Apr 7, 2002 | 03:18 PM
B00ST2nR's Avatar
Default Re: DYNO PROBLEMS (p-town)
dude. Somethings GOTTA be wrong with your car. That is WAY Too low for a GS-R. Either your car has problems, or that Dyno has problems.
Try checkin your car out...
Old Apr 7, 2002 | 03:46 PM
vteg's Avatar
New User
When I dynoed about 6 months ago I got 137 on a 1999 with CAI. This was on a 99 gsr with 35k.
Old Apr 7, 2002 | 03:48 PM
IN VTEC's Avatar
Default Re: DYNO PROBLEMS (vteg)
I think mine would dyno about that much stock too. I dyno'd 146 and 116lb*ft 2 months ago with K&N RU-3130, DC 4-2-1 SS Header, and axle-back exhaust.
I need more power.
Old Apr 7, 2002 | 04:00 PM
csufweed's Avatar
Default Re: DYNO PROBLEMS (IN VTEC)
yup the numbers might be a little low... how about something as simple as a tune up and oil change? if the timing belt is slipping you will know... why water pump, do you get a strange noise? valve adjustment? any ticking noise? i would just get a tune up and check the timing and whatever to make sure its set correctly. if your dyno is low, its not low by much, only a few hp.
Old Apr 7, 2002 | 04:28 PM
Audipwr1's Avatar
Default Re: DYNO PROBLEMS (csufweed)
water pump. timming belt cause car is 6 years old and u gatta do those at 6 years or 90k
valve adustment, valve lash might be causing hp problems
im looking for other suggestions of why hp is so low
130's is what ls get on the dyno
Old Apr 7, 2002 | 04:57 PM
mikecel79's Avatar
You need to give us more details. Does the engine smoke at all? When was the last time you had a tuneup? Oil change? Compression numbers?
I doubt changing the timing belt is gonna give you any more HP, same for the water pump too. The valve adjustment may help though.
Old Apr 7, 2002 | 05:23 PM
shadowdawn's Avatar
Default Re: DYNO PROBLEMS (mikecel79)
I beg to differ that LS's get 130s on the dyno stock, a car has an average drivetrain lose of 21% from the engine output to wheels, so I doubt heavily a LS is getting 130 exactly to the wheels when crank peak hp is only 10 more then that.
Old Apr 7, 2002 | 05:42 PM
Audipwr1's Avatar
Default Re: DYNO PROBLEMS (shadowdawn)
no engine smoking at all. Oil change had been about 1500 miles before run.
had compression tested by crappy honda dealership which did it when the engine was cold numbers
175 in all 4 cylinders
waterpump and timing belt are just to make sure my car doesnt blow itself up
hybrider's Avatar
more like 115-120 stock for LS's
as for the 137 on the stock B18C1, yes it is kinda low...i got 143whp stock form, with a VERY restrictive cat, this on a 95 GS-R with more mileage
just do a tuneup, oil change, check out the cat (maybe its slightly clogged) etc
Old Apr 7, 2002 | 05:53 PM
csufweed's Avatar
Default Re: DYNO PROBLEMS (hybrider93)
the LS gets 120 at the wheels... the gsr should get about 140... ITR about 160
of course every car is different...
Old Apr 7, 2002 | 05:54 PM
Audipwr1's Avatar
to check cat for clog just take off header and look inside it with a flashlight or something???
Old Apr 7, 2002 | 07:59 PM
vteg's Avatar
New User
The morning my dyno was done, I replaced the oil, spark plugs and did a valve adjustment. Tranny fluid had 5k miles on it. I pulled off my bypass valve afterwards. Made the car louder, but I don't know if it made an hp difference. Here is my dyno
[Modified by vteg, 9:02 PM 4/7/2002]
BTW, I had been running synthetic for about 8k miles also.
[Modified by vteg, 9:06 PM 4/7/2002]
Old Apr 7, 2002 | 08:10 PM
WRXRacer111's Avatar
My '95 RS with made 125.5hp and ~110tq at the wheels with 63k on the motor, a DC intake, advanced timing while sucking 88 degree ambient air and 100% humidity (raining outside at the time)... hehehe, yay for Wednesday-motors. My tq numbers seemed low to me but yours are hurting even more.
137 sounds very low for a GS-R. Your timing belt shouldn't make a difference, unless your timing belt jumped a few teeth and your timing is off... Either the belt works or it doesn't (ie, it's broken and you'd be hating life then)
BTW, might want to check on this, but I think the service interval on the timing belt is 60k. At least, that is what I was told by a Honda dealership.
Old Apr 7, 2002 | 08:17 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: DYNO PROBLEMS (WRXRacer111)
My GSR made 152hp at the wheels with a Comptech ice-box and Type R exhaust.
After getting the JDM 4-1 headers, carsound cat, and Civic Type R cams, and adjustable cam gears my car made 165 at the wheels.
Later on got the RSR exhaust and a test pipe the hp's got upto 169 at the wheels.
Check your compression it could be the problem.
Old Apr 7, 2002 | 08:21 PM
sa21199's Avatar
Default Re: DYNO PROBLEMS (comptechgsr2000)
definately do a compression test.
Old Apr 7, 2002 | 08:28 PM
vteg's Avatar
New User
I need to go buy a compression tester. There was one guy on this board that had a very bad dyno with CAI, about 138. He gained like 17hp from header, cat and exhaust.
My motor should break 50k this week. Since my engine sucks, but I love my car, I will probably keep it as a commuter, and buy a toy to mod. 92 mr2 turbo, 3rd gen rx-7.
Old Apr 7, 2002 | 08:39 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
I recently did a compression check on my car and I had around ~210 at each cylinder. Is 175 still within factory limits or is there a possible problem lurking about? Just wondering? That may be your problem.
[Modified by Gee3, 11:44 PM 4/7/2002]
Old Apr 8, 2002 | 07:10 AM
Audipwr1's Avatar
Default Re: DYNO PROBLEMS (Gee3)
acording to helms 175 is within specs for the motor
what else could i do to see if its the motor that is the problem, leak down test?
Old Apr 8, 2002 | 09:53 AM
berkel's Avatar
Hi,
Where is your engine timing? You can try it at ~16 degrees, and maybe 18 to see if you get more power without pinging...
Try some techron or Regane to clean out your fuel injectors.
Have you replaced the fuel filter?
Make sure valve clearances are good, this can make quite a difference alone.
How are your plugs and wires?
Was this on a dynojet 248C? If not, numbers may not compare directly....
Other thoughts?
FB
Old Apr 8, 2002 | 12:21 PM
houston's Avatar
Default Re: DYNO PROBLEMS (berkel)
possibly a clogged cat.. bad timing, dirty air filter, easy stuff.
Old Apr 8, 2002 | 12:54 PM
Audipwr1's Avatar
Default Re: DYNO PROBLEMS (houston)
so im looking at this then
change fuel filter
check timing, check cat, check wires/plug
throw some injector cleaner in
new air filter
anything else, i want all the stupid stuff cleared up before i hit the dyno again
