drivers window issue
Old May 15, 2016 | 12:27 PM
portugueboy10's Avatar
Default drivers window issue
Whats up HT my drivers window wont go up or down but all other windows do, i have a new regulator and motor i tried replacing the main window switch and it didnt work, but sometime i can lower and the windows including the driver but then it wont go back up i have to keep pressing the button then it will go but the other windows some times is the same problem and the drivers window but i can make them go up or down on each separate switch on the door any ideas?
Old May 15, 2016 | 02:18 PM
fcm's Avatar
fcm
Old Fart
Default Re: drivers window issue
Check wiring in the door boot, [wires that run from door into cap of car] it is a common problem to get broken leads in the boot, especially the drivers door, [opened and closed the most]. 94
Old May 15, 2016 | 03:50 PM
The window works off and on i tried it today and it went up and down but if i drive for 20 mins and put the window down it wont go back up for a few hours
Old May 16, 2016 | 09:55 AM
fcm's Avatar
fcm
Old Fart
Have you checked the wiring in the boot yet.94
Old May 16, 2016 | 11:48 AM
I havent checked it yet window has been working fine all day today
Old May 17, 2016 | 08:23 PM
wunfstgsr's Avatar
Loved
Community Favorite
Its probably a broken or kinked wire in the door boot like mentioned or a loose wire in the harness going to the main switch. Sometimes it might get a contection and other times it might get pulled away or something so just because its fine one day dont mean its not gonna come back.
Could also be a low battery causing the issue is there any dip in the electric system when turning the windows down when this happens with the engine running?
gr_elvis
Honda CR-V & Element
Apr 26, 2018 07:15 AM
1992db2
Jul 21, 2017 05:05 PM
spinningpedals
Aug 12, 2016 06:34 PM
chris4x4
13
May 8, 2011 10:39 AM
auditech187
Jun 25, 2008 10:34 AM
