Driver Side Head Light Is Dead.
Old Dec 3, 2006 | 06:47 PM
Import_spoon's Avatar
Default DELETE
DELETE
Modified by Import_spoon at 7:58 PM 12/3/2006
Modified by Import_spoon at 5:28 AM 12/11/2006
Old Dec 3, 2006 | 06:54 PM
bshshondaman06's Avatar
TRIED not tryed. there is a fuse, check that.
Old Dec 3, 2006 | 06:57 PM
Default Re: (bshshondaman06)
oh sorry my bad. I already checked the fuse and its ok.
Old Dec 3, 2006 | 07:30 PM
Bump
Old Dec 3, 2006 | 07:53 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (Import_spoon)
Trace the wiring far back as you can, how're the contacts inside of the plug going to the bulb?
Old Dec 3, 2006 | 08:35 PM
Default Re: (CleanLikeJdm)
do you mean trace as in following into all the wires that are together and has the black tube around it? I don't get what your trying to say here "how're the contacts inside of the plug going to the bulb?"
Old Dec 3, 2006 | 08:47 PM
Blk-dc2's Avatar
its most likely the harness....me and my friend have burned them out...do you use after market lights????
Old Dec 3, 2006 | 09:03 PM
qwk db8's Avatar
Default Re: (BLACK-dc2)
Old Dec 4, 2006 | 02:40 AM
1DA2NV's Avatar
check your relay, and check here for the diagram http://www.acuraoemparts.com/d...ch=no this is for the 1992-1993 teggy and 1994 and up is here
Old Dec 4, 2006 | 04:37 AM
i'm using sylvania bulbs. These are the only set i've been using since i bought my car. That might be it. I pretty sure its my harness.
Old Dec 4, 2006 | 01:39 PM
Com on need help on this.
Old Dec 4, 2006 | 02:09 PM
Code Blue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_spoon &raquo;</TD></TR><TR><TD CLASS="quote">Com on need help on this.</TD></TR></TABLE>
do like the other users told you, check the harness.
unplug the socket from the bulb, check inside that socket, does everything look ok? lots of rust or things missing?
look at where the wires go into the socket, are the wires in all the way? anything broken?
take off the factory wire loom and check the wiring up as far as you possibly can, is anything grounding out? any wires severed?
grab a multimeter and turn your headlights on, with the socket unplugged, check to see if anything is reading, if only a small amount, or if when you plug the bulb back in its dim, check your grounds.
check the headlight relays.
when did this problem occur? did you just turn the headlights on one night and the driver side was out? did you hit a huge bump? any accidents, etc?
Old Dec 4, 2006 | 02:23 PM
Dealer Leaf's Avatar
Take a volt meter, set it on DCV 25 (or any other setting above 12) test to see what voltage you get on your battery terminals then test your head light plug w hile the cars head lights are on. May help to see if your even getting current to your lights.
Old Dec 5, 2006 | 11:51 AM
Code Blue's Avatar
Default Re: (Dealer Leaf)
have you fixed the problem?
in for the update
Old Dec 5, 2006 | 06:59 PM
Default Re: (Code Blue)
naw haven't got time to check up on it. Been too busy working so now i drive my dads 1989 Mazda Rx7. Its a POS so i don't beat on it because its pretty junky. Trying to get money for my B18 build.
ajason24
36
Jun 4, 2009 05:14 PM
2.2L EH2
Oct 10, 2006 11:10 PM
RHGSR01
Oct 30, 2004 02:12 PM
Nic
Oct 18, 2004 12:37 AM
t0ekn3e
Aug 31, 2004 11:00 PM
