driver-side door is sagging.. solution?
Old Jul 5, 2006 | 05:20 AM
reno96teg's Avatar
Default driver-side door is sagging.. solution?
so my driver-side door is sagging and it's hitting the striker upon closing the door. i seem to have narrowed the problem down to the lower hinge. i'm not sure if it's the hinge itself, or the pin that is worn, but it's likely one or the other.
so, now i'm wondering what's the best solution..
it doesn't seem like i can buy just the pin. i'm not even sure how to remove it.
i guess i can adjust the hinge itself, but that seems like a temporary solution.
there is also the option of replacing it entirely, another thing i don't feel like doing.
anyone out there run across this before? what did you do?
thanx!
Old Jul 5, 2006 | 05:41 AM
bluemax189's Avatar
Default Re: driver-side door is sagging.. solution? (reno96teg)
need to replace the hinge. only solution that will work for more than a few days.
Old Jul 5, 2006 | 11:14 AM
davidluko's Avatar
Maybe the door was just taken off and put back on too low. Why don't you try to unbolt the door and adjust it? Simple solution...
Old Jul 5, 2006 | 11:17 AM
jdm_bones's Avatar
Default Re: driver-side door is sagging.. solution? (bluemax189)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluemax189 &raquo;</TD></TR><TR><TD CLASS="quote">need to replace the hinge. only solution that will work for more than a few days.</TD></TR></TABLE>
This is the only way, and I would stop hanging on them while they are open!
Old Jul 5, 2006 | 11:21 AM
reno96teg's Avatar
Default Re: (Hatch_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_R &raquo;</TD></TR><TR><TD CLASS="quote">Maybe the door was just taken off and put back on too low. Why don't you try to unbolt the door and adjust it? Simple solution...</TD></TR></TABLE>
the door has never been touched. i should know, i've had the car for over 6 years.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones &raquo;</TD></TR><TR><TD CLASS="quote">This is the only way, and I would stop hanging on them while they are open!</TD></TR></TABLE>
i don't hang on the door.. ever. i think it's just age and being opened and closed thousands of times.
i say that it's a worn pin or hinge, not maladjustment, because there is play in the hinge itself. i can see it.
Old Jul 5, 2006 | 11:43 AM
davidluko's Avatar
What 'pin' are you talking about? Are you talking about the little hollow tube pin? Because that is not there to support to door at all, it's there to keep the door from swinging closed when open, and opening too far.
But from what you said about play in the hinge, I geuss replace that. I mean, if you can see the problem happening, did you really have to post about it on h-t?
Old Jul 5, 2006 | 06:43 PM
reno96teg's Avatar
no, i'm not talking about the door checker.
even though i do think it is the lower hinge, i want to be sure, hence why i'm asking. i'm sure someone else has experienced this. i would also rather not spend $30+ in replacing the entire hinge, if it's not necessary (i.e. replace this "pin" instead, or whatever it is that appears to have worn in the hinge)
Old Jul 5, 2006 | 07:00 PM
6doorsentra's Avatar
unlosein all the bolts take door off, put back on and do it right...just bolts, quick 10 minute thing
seriously dont buy anything
Old Jul 5, 2006 | 10:55 PM
davidluko's Avatar
Default Re: (6doorsentra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6doorsentra &raquo;</TD></TR><TR><TD CLASS="quote">unlosein all the bolts take door off, put back on and do it right...just bolts, quick 10 minute thing
seriously dont buy anything</TD></TR></TABLE>
Yea that's what I was suggesting. Personally, I'd rather try to do it the quick and easy way and see if that works, if not then start buying parts. Just loosen the bolts on the hinges and try adjusting the door and then get someone to tighten the bolts back up when you think you've got it right.
Old Jul 5, 2006 | 11:02 PM
vinai's Avatar
My car is ten years old both sides were sagging. I just popped both fenders off and adjusted them at the hinges and she is straight and true now. Did not replace anything. It's been almost a year since I've done it and it still lines up true.
Old Mar 16, 2010 | 08:28 PM
Jimmy's Avatar
Global Moderator
Had to bump this old thread.. my driver side door is actually sagging and makes a ''pop'' noise opening and closing..
I'm gonna try readjusting, but does anyone have any idea what the hell this ''popping'' noise is?
Passenger side is perfect.. need to get all these little things fixed..
Old Mar 16, 2010 | 09:35 PM
OrangeTeggy's Avatar
Mines doing the same thing so if I pop off fenders and doors I retighten them they wont rub without getting new pins and bushings cause thats what i was told I needed?
Old Mar 16, 2010 | 09:45 PM
integra_101's Avatar
I had this problem too. my hinge got loose and i always gotta bolt it back up. 2 hrs of sitting on the door through the window(2006 italy worldcup champion game, roaming the streets) lol.
Old Mar 19, 2010 | 07:36 PM
Jimmy's Avatar
Global Moderator
Old Mar 19, 2010 | 08:42 PM
Mr. Glove's Avatar
TRIAL USER
It's the hinge 100%. Same thing that had happened to my Ae86. Door kept getting banged up cuz that thing. It's a killer.
b18cEK
Apr 7, 2008 06:23 PM
mortificationrock
Jan 27, 2008 07:31 AM
japspecjohn
20
Aug 24, 2004 06:10 PM
kniob
Mar 27, 2004 03:06 PM
CB_ejcoupe
Jan 26, 2004 02:35 PM
