driver motor mount...again
ok so last thread i had trouble getting the right part, so i went straight up to acura and got the right one after shellin out like 130 dollars, so its on, its oem, but the flippin engine rocks like its still broken!!! the mount moves within the bracket on the engine bay from front to back like its not even bolted down! do i have to put some kinda massive spacers on each side or what? and my car vibrates on acceleration at like 65-80 i dunno if its related or not. guhhhhhh
When you say the engine rocks, in which direction? From drivers to passanger side or from front to back.
Also, are you sure your torquing/tightening all the bolts down. There are fours bolts associated with the drivers side mount. 2 vertical studs on which the mount slides onto and then there are two nuts that hold it down. 1 vertical bolt that goes kind of between the two studs. And then 1 horizontal bolt that goes through thte actual mount (throught the bushing) and tightens into the bracket.
Normally, when the engine is rocking it is due to the rear lower mount.
Ali
Ali
