Door Panel Removal
How do you remove the door panels to a 95 integra? I am replacing the power door lock motor on the driver's side and can't seem to find what is holding the panel in at the bottom. Also can anyone tell me how to remove the plastic in front of your dash gauges. Thank you!
door panel:
remove screw on door handle, remove screw in ashtray thing on armrest, remove the plastic screw in the front of it kinda under where the mirror is and make sure there are no other visible screws...
after you get the screws out, pry at the door until you feel it pop and then pop it off all round the back of it at the door jamb part, and along the bottom edge and the door should slide off its place on the window by you pulling it straight back and up a little torwards the rear of the car....you'll also need to remove the door handle thing by pushing the little purple plastic piece to unclip the metal power door mechanism (you'll see what im talking about) and then pull the metal hook looking thing for the doors out of the purple thing and slide the door off the handle....then it should be off.
instrument cluster:
remove two screws in the black surround above the steering wheel, grasp the bottom of that black surround with both thumbs and forefingers at the bottom near the steering shaft thing and pull firmly and straight back and it should pop out....there is little clip things that hold it on on the top that are a pain sometimes.
to get the cluster out there is three screws, one in the middle at the top and one at the bottom on each side, remove those carefully making sure not to drop them and it should come out for you to be able to work on the back of it if you so want to.
instrument cluster:
