door panel
Old Nov 22, 2006 | 11:31 AM
chris3k's Avatar
Default door panel
i tried using the search engine but nothing came up so here it goes, i am having a hard time putting the passenger inside door panel back on, any ideas?
Old Nov 22, 2006 | 01:46 PM
vladd's Avatar
Default Re: door panel (chris3k)
what exactly are you having trouble with? when i put them in i take the little mirror covers out and slip the panel over the top first. then i pull it down a little, pop the mirror cover back in, and push the panel clips into the door.
Old Nov 22, 2006 | 04:48 PM
waddy41's Avatar
u juss need to pop the panal back in
Old Nov 22, 2006 | 04:57 PM
iH8RICERZ's Avatar
Default Re: (waddy41)
the tricky part on mine is the top. You have to make sure the top is aligned in in place before you can pop/hit the rest of the panel into its clips back on the door
Old Aug 5, 2007 | 08:53 AM
ac_attak's Avatar
Default Re: (iH8RICERZ)
I am having trouble with this now. I can't get the top of the panel in place. I can the side next to the mirror to go down fine, but the back end along the top i can't get in at all. I am doing the same thing as the video on t-i shows, but it still won't go in.
Old Aug 5, 2007 | 09:56 AM
ac_attak's Avatar
Default Re: (ac_attak)
I finally got it by sliding the top in back end first, instead of front end first(as was shown in the video). Went in first try that way.
RSX_S
Jul 3, 2008 07:34 AM
Mike V. Dubs
May 19, 2008 08:31 PM
madmanmulligan
Mar 30, 2006 08:22 PM
inty2511
Mar 25, 2004 05:27 PM
hotsots
Jun 25, 2001 04:51 PM
