Doing interior work...can someone help me?
Old Jan 9, 2004 | 03:28 PM
Sprockett's Avatar
Default Doing interior work...can someone help me?
I want to replace the carpet, replace a burnt out light bulb behind the dash, and a couple of other things. Do I have to remove the engtire dash? If so, how do I do that? Where are the screws?
Thanks
Tyler
Old Jan 9, 2004 | 03:44 PM
SIanara's Avatar
where on the dash? speedo? tach?
Old Jan 9, 2004 | 04:19 PM
Sprockett's Avatar
Well, as I look at the dash, the gauge cluster lights must be burnt out on the left side because that side does not light up (the temperature gauge and the tach from 1000rpms - 3000rpms). The rest of the gauge cluster is fine.
What all has to be removed to take out the carpet?
Old Jan 9, 2004 | 05:34 PM
Bimmer99's Avatar
Default Re: (Sprockett)
i believe all the seats, door sills, kick panels ,center console and trunk release/fuel door release trim.
as for your dash light problem it does indeed sound like a bulb problem , i think all you have to remove are the 2 screws that point up in the bezel . i usually use a stubby phillips screwdriver
curtie94
Feb 21, 2012 11:47 AM
ajvb65
May 22, 2008 04:49 AM
rjforant
May 13, 2005 03:59 PM
Projected
Sep 30, 2003 09:10 PM
