Does rim size affect ride height?
Old Sep 3, 2001 | 07:08 PM
94LSTEG's Avatar
New User
Default Does rim size affect ride height?
I currently have 17's on my teg. I have KYB and Neuspeed sport springs along with the WW type II kit. The ride is horrible. I can't get up drive ways without scraping the bottom. I recently got 95 GSR rims. My question is, if I go from 17's to 15's will it make my car even lower? Do you think I'll feel the difference is acceleration also?
Old Sep 3, 2001 | 07:22 PM
GTEater's Avatar
Default Re: Does rim size affect ride height? (94LSTEG)
depends on what size tires..........17's with 205/40/r17 are a tiny bit taller than the 15's with stock 195/55/r15.......might be the same if you get 205/50/r15 and yes you should notice a big difference in ride quality......since low pro tires sidewalls are a lot stiffer than thicker wall tires......and you will feel a difference in acceleration
Old Sep 3, 2001 | 07:52 PM
H23 Power's Avatar
Default Re: Does rim size affect ride height? (GTEater)
a larger tire will put you higher up...try this out: http://www.dakota-truck.net/TIRECALC/tirecalc.html
Old Sep 4, 2001 | 08:35 AM
crookedletterd's Avatar
New User
Default Re: Does rim size affect ride height? (01GSR)
yea true, when i had my stock LS wheels with H&R race springs, my car was very low. then i put 17x7.5 wheels with 205/40-17 and the car was not as low at all. i compared the two wheels side by side and the tires i got, potenza RE730's were a bit taller so my car is not that low anymore. you can tell its lowered from no wheel well gap but from the ground its not that low.
Old Sep 4, 2001 | 03:19 PM
94LSTEG's Avatar
New User
Default Re: Does rim size affect ride height? (integls98)
Thanks for the response guys
JuneBugDrfter
Jul 18, 2010 12:16 PM
LSxVQ35
Aug 24, 2008 06:41 AM
tonezilla
Mar 6, 2006 05:06 AM
Sukebei Oni
Acura TL, RL & ZDX
Dec 15, 2003 12:02 AM
typer77
Apr 12, 2002 04:32 PM
