Do I need a test pipe? or cat?
Old Nov 3, 2004 | 10:30 PM
IloveAPC's Avatar
Default Do I need a test pipe? or cat?
Hey I have a question Im running ls/vtec (gsr head) and I was curious If i run a jdm header and 2.5" piping out can i just have piping from the header out or is there another o2 sensor or something required for the cat or test pipe.
Old Nov 4, 2004 | 05:49 AM
IloveAPC's Avatar
Default Re: Do I need a test pipe? or cat? (IloveAPC)
up
Old Nov 4, 2004 | 05:57 AM
dFreezy's Avatar
is your car obdI or obdII?
Old Nov 4, 2004 | 06:08 AM
PLRacer's Avatar
Default Re: Do I need a test pipe? or cat? (dFreezy)
if your car is 97+ then there is another o2 sensor in the stock cat.
Old Nov 4, 2004 | 06:49 AM
IloveAPC's Avatar
Default Re: Do I need a test pipe? or cat? (PLRacer)
My car chassy is 2000... 2000 ls block.... 99 gsr head. But Im running a obd2 - obd1 jumper and a p28 ecu.
Old Nov 4, 2004 | 07:58 AM
tnord's Avatar
i have a 2.5'' Cat for sale if you want it.
Old Nov 4, 2004 | 12:23 PM
btownteg
Guest
Posts: n/a
Default Re: Do I need a test pipe? or cat? (tnord)
if you are running obd-1 then you only need the one o2 sensor
Old Nov 4, 2004 | 10:45 PM
IloveAPC's Avatar
Default Re: Do I need a test pipe? or cat? (btownteg)
so if i only need the one thats on the header what do i do with the existing one on the cat?
Old Nov 4, 2004 | 10:51 PM
99-DC2's Avatar
Unplug it from the connection and keep it as spare.
littlegreenb18
Feb 24, 2006 01:19 PM
user 996328629
Dec 18, 2002 07:20 PM
Jmm0056
Jan 27, 2002 05:47 AM
Rob Dizzle
Dec 1, 2001 06:15 PM
