Do i need....
Old Nov 6, 2005 | 10:01 AM
gtpblax11's Avatar
Default Do i need....
if i buy new headers and cams, do i need a performance exhaust tooo? i have a aftermarket muffler just not the full exhaust so idk if there wont be enuff exhaust flow or too much back pressure or watever?
Old Nov 6, 2005 | 10:04 AM
Ichigo's Avatar
It would be tter if you do.
Old Nov 6, 2005 | 12:07 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Do i need.... (gtpblax11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtpblax11 &raquo;</TD></TR><TR><TD CLASS="quote">if i buy new headers and cams, do i need a performance exhaust tooo? i have a aftermarket muffler just not the full exhaust so idk if there wont be enuff exhaust flow or too much back pressure or watever?</TD></TR></TABLE>
Based on your question, it would be best to do some reading/searching here first. Start with the Integra FAQ stickied at the top of this forum. It has many informative links.
As for your question, no you do not NEED a performance exhaust. You should determine your budget and what your goal is for the car. If you don't want to go forced induction (i.e.: turbo, nitrous, supercharger), then most people start with an intake/header/exhaust combination. There are hundreds, if not thousands of manufacturer combos you can choose from. This combo will let your car "breathe" better from the intake all the way to the exhaust.
From there, you can go a hundred other different ways too. Read up some more and search.
Old Nov 6, 2005 | 12:14 PM
Backk InTheDA's Avatar
I hate everything
Default Re: (R34lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R34lude &raquo;</TD></TR><TR><TD CLASS="quote">It would better if you do.</TD></TR></TABLE>
Old Nov 6, 2005 | 01:04 PM
Monkey Z.'s Avatar
if you plan on staying N/A get an exhaust that has around 2.25 in piping... anything too big and the exhaust pulses (not backpressure, that's a misconception) will have too much room therefore giving you less power. A 3in piping exhaust system can flow up to around 800 hp, so think of it that way.
Old Nov 6, 2005 | 01:10 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
your stock exhaust will bottleneck the flow. you should get a 2.25" exhaust, unless youre gonna have a wild all motor setup. then id get 2.5" piping
Tyler Con
Aug 29, 2007 10:00 PM
baconcrx
15
Jun 24, 2006 09:21 PM
bonestock91
Mar 9, 2006 01:36 PM
4drRacer
32
Apr 27, 2002 09:58 PM
Dawsonb17a
Jun 15, 2001 07:56 PM
