DIY trunk brace problem, help
Old Mar 16, 2003 | 10:23 PM
Specialk's Avatar
Default DIY trunk brace problem, help
so i got around to doing the trunk brace bar on my sedan today got the bar the hardware and everything. cut the bar to length, drilled the holes. then my friend took out the existing bolts while i was doing something else and when i went to mount the bar the bolts wouldnt go in all the way, not even the factory ones. it kinda seem like its being crossthreaded but no matter how many times i try it will never go in right. im wonderin what could be causin this, how can it be fixed, and is there any danger in drivin my car with these bolts not all the way in? any help is very very appreciated, thanks.
Old Mar 17, 2003 | 11:10 AM
Specialk's Avatar
Default Re: DIY trunk brace problem, help (Specialk)
ne1?
Old Mar 17, 2003 | 12:27 PM
cjohnson_2's Avatar
That sounds weird. Ive taken mine out plenty of times and nothings happend. Although I did read once that your not suppose to take them both out at once.. only do one at a time. Thats what i do. when you look down the holes does it look like its uneven? almost crooked? Just try to make sure the trunks lined up with the holes..
Old Mar 17, 2003 | 05:47 PM
Specialk's Avatar
Default Re: DIY trunk brace problem, help (cjohnson_2)
oh crap he took both out at the same time, please tell me its fixable somehow.
Old Mar 17, 2003 | 07:46 PM
cjohnson_2's Avatar
You just have to re-align the holes in the trunk to where the threads are on the frame. . Im guessing its probably a pain in the *** but you should be able to do it.
sloweredcivic
Sep 19, 2010 11:59 AM
gofast300@gmail.com
Suspension & Brakes
Jan 23, 2009 02:05 PM
ICeDoUt
Welding / Fabrication
14
Sep 15, 2005 07:25 PM
mark_is_gay
Mar 25, 2005 03:07 PM
94gsr4dr
May 15, 2003 11:37 AM
