DIY install of a JDM ITR/Front End conversion
Old Oct 27, 2005 | 01:53 PM
Formula's Avatar
Default DIY install of a JDM ITR/Front End conversion
I have a 94' DB8 4door Integra which seriously needs a JDM/ITR front end conversion. I have the JDM/ITR front end conversion with everything brand new from Honda. I am planning to do the install myself. I am planning on getting everything painted and color matched before I do the install and touch up anything that needs it after wards. I do all my own engine work and tuning but I've never really done any major body work. I do know how to MIG and TIG weld but like I said I never had to do any major body work on any car before. If any one has done a JDM/ITR front conversion on a DC, or DB8 chassis Integra the DIY way please let me know. Any help would really be appreciated. "Go JDM"
Old Oct 27, 2005 | 01:59 PM
juicy.fn's Avatar
Default Re: DIY install of a JDM ITR/Front End conversion (Formula94)
You can do this DIY. You dont need to weld
https://honda-tech.com/zerothread?id=1346217
Old Oct 27, 2005 | 02:08 PM
Formula's Avatar
Cool! If you don't have to weld then that makes it alot easier.
So is there anything really complicated are hard that you have to do.
Old Oct 28, 2005 | 12:59 PM
Formula's Avatar
Yo! Does anyone out there know how to put on a JDM/ITR front end conversion?????????
I know someone out there has to know. I just want to know some of the details and steps to install it.
PLEASE HELP!!!!!!!
Old Oct 28, 2005 | 01:03 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (Formula94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Formula94 &raquo;</TD></TR><TR><TD CLASS="quote">Yo! Does anyone out there know how to put on a JDM/ITR front end conversion?????????
PLEASE HELP!!!!!!!</TD></TR></TABLE>
The link above shows you everything. Plus the search feature for JDM conversion/front end/etc will yield hundreds of results.
Old Oct 28, 2005 | 01:09 PM
Formula's Avatar
Default Re: (shamoo)
Hey, thanks shamoo. I will check out those sites and see what I can find out.
Old Oct 28, 2005 | 01:35 PM
Formula's Avatar
I couldn't find anything on the sites above and the search server is saying its down.
I will still try to find a site, but if anyone knowns anything about installing a JDM/ITR front end please let me know.
Old Oct 28, 2005 | 01:38 PM
shamoo's Avatar
So you're saying that this link: https://honda-tech.com/zerothread?id=1346217 doesn't tell you how to do it?
Hell, it's titled "JDM DC2 Integra Conversion - Official HOW TO INSTRUCTIONS"
Here is the post in it's entirety:
Originally Posted by JDMoMo
Ok guys, finally got some time to start doing my thread on JDM conversion.
This is very easy and will show how to do this WITHOUT WELDING!
I do not take responsibility for anyone's car.
If you're not sure or don't like my idea, take it to a professional. Thank you.
Tools:
1. Wrench
2. Socket set (12mm and 14mm will be a must)
3. Screws (depends on the holes - 3/8" size)
4. 16 gauge wire - about 25ft to 50ft sill be just fine
5. Butt connector
6. Low power drill machine[
IMG]http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTAzOTgwNzZzNDEzZGZkMzF5NTQx.jpg[/IMG]
7. Spot weld bit
8. DO NOT USE DRILL BIT! IT WILL TAKE YOU FOREVER TO DRILL EACH HOLES!!!
9. Electrical tape
10. Wire connectors for connecting the headlights.
Here's an example:
11. Screw driver
Hope Im not forgetting anything...if so, I'll add on next time I remember.
Ok. So now you have your tools. Now make sure you have all of your JDM conversion parts.
1. Front bumper
2. Headlights
3. Radiator support
4. Hood
5. Fenders
6. Bumper support
7. Bumper reinforcement (or you can use the USDM ones
8. Grillie (goes above the bumer, between the headlights)
Ok so now since you have all these parts, you're ready to begin.
1. First you have to take out the front bumper. You'll need a screw driver for that.
2. Unscrew the fender liners from the fenders and the bumper
3. Pull the bumper off
4. Take out all the bolts from top of the bumper support
5. Take out the headlights (SAVE THE BOLTS)
6. Unbolt the bumper support
7. Take out the fenders. There are bolts on the top and you'll find one bolt when you open the door. When you open the door, you'll spot it through the door and the fender. You'll also need to remove the stock side skirts to get to the other two bolts for the fenders.
8. And ofcourse, the hood, unbolt that off.
OK, so you're ready to start taking off the radiator support. You'll have to use the spotweld bit to remore the spot welds. There are about 40 to 50 spot welds. Trust me, with the spot weld bit, you'll have it off in a few hours.
1. Take out these spot welds
and these....
***REMEMBER, NOW YOU KNOW WHA THE SPOT WELDS LOOK LIKE, SO TAKE THEM ALL OUT. EVERY CAR HAS DIFFERENT AMOUNTS OF SPOT WELDS OR WHERE THE SPOT WELDS ARE. BUT TAKE OUT ALL OF THEM ON EACH SIDES. SOME YOU WON'T HAVE TO MOVE BECAUSE THEY'RE NOT CONNECTED TO THE BODY FRAME. TO FIND THAT, JUST FEEL THE OTHER SIDE OF RADIATOR SUPPORT AND SEE IF THERE'S A BUMP AND IF NOT, THEN YOU WON' TNEED TO WORRY ABOUT THAT SPOT WELD BECAUSE IT'S NOT CONNECTED TO THE BODY FRAME***
Here are some more examples of the spot welds after they're drilled out.
Some aren't all the way drilled because it's to show you how it looks like.
The passanger side looks really bad because I didn't have the spot weld bit then and I used a regular drill and it fucked it up pretty bad and I got to a point where I started cutting the radiator support out.
http://www.we-todd-did-racing....x.jpg
2. Now that all the spot welds are cut off, its still going to be very tough to take them out and you'll new a CROWBAR to move the radiator support.
3. Put the JDM radiator support. Once you put it in place, it should look like this.
4. You will have to bend the AC line a little bit to fit the radiator support. Its very easy to do that, with your hand. Here's an example of the AC lines and how it looks after you bend it and put the radiator support on
5. Now it's time to put on the radiator support. To do that, you have to bolt it on first so you can connect the radiator on. You'll bolt it on where the USDM bumper support was originally bolted. Here's a picture of where the holes are:
6. After it's bolted on, it's going to be a lot easier for you to bolt the radiator on and see the fittings for the fenders.
7. Now it's time to cut off some parts of the body to fit the headlights on. Here's to show you where to cut from.
8. Now you are ready to put the headlights on to see how it fits. For people, that have the HID like me, there are a few more extra steps. You'll find those instructions in the end of this setup.
Here's a pic to show you an example of the headlight installed.
9. Now put on the fender to see how it fits. They should fit perfectly. Here are some pictures to show example:[
IMG]http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTAzOTkzNjZzNDEzZGZkMzF5NTQx.jpg[/IMG]
10. Ok, now you can take out the fenders and the headlights off to put on the bumper support then you're going to put them back in. To do that, you'll unbolt those bolts that are holding the radiator support. Then install the bumper reinforcement support and the radiator support on together. Make sure you use the factory bolts because those are not the same grade as just any bolts you'll find in Home Depot. Just those 4 bolts will hold the radiator support perfectly. We've tested it by having me and my friend sit on the radiator support. They don't move. But don't just leave the whole thing on with only 4 bolts.
11. Now you should start drilling holes on your radiator support matching the original holes you made while taking out the radiator support. Use the strongest bolts you can get from home depot or wherever you get them from.
Heres an example w/ some pictures:
12. Ok, you should be done with bolting by now.
13. Now put the headlights on first and then put the radiator support on. Once you're done, put the bumper support on. This is the support that connects to the reinforcement. Bumper support holds the front bumper.
14. You're also going to have to change the hood latch. You can either buy a 90-93 latch and cable or you can use the one from your car. Even though I have used the original cable, I am going to change it to a DA cable because it's a lot better and longer than the DC2. But the latch is perfectly fine. All you have to do is turn it around and install it. The original bolts fit in just perfectly. Here's a picture:
15. Install the hood now if you already haven't. Close it all up to see if everything fits. If so, then bolt on everything if you already haven't bolted the parts on. I did my final bolting in the end, after I saw that everything fit perfectly.
I hope this helped people. Took me 3 hours to write this up. I can't think at the moment but ill go over the whole thing to see if I'm missing anything. If so, I'll add in later. If you have any questions, just e-mail me and I will be happy to answer them for you. Thanks
Here are some final pictures after it's done!
This is what it will look like once it's done. But in candy apple red.....w/ CF hood.
***UPDATE 9/24/05***
Here's the diagram for the headlights. Originally made by <U>ZIEX73REW</U>
Old Oct 28, 2005 | 02:32 PM
t0ekn3e's Avatar
wow had to qoute from the link
Old Oct 31, 2005 | 12:52 PM
Formula's Avatar
HEY shamoo; YOU DA MAN!!!!!
Thanks dude. When I looked for this thread the other day I couldn't find it. I guess I'm just a dumm ***.
I will keep you guys posted on the conversion and let you know if I have any problems.
Once again, Thanks shamoo!!!!!
Old Oct 31, 2005 | 01:00 PM
juicy.fn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Formula94 &raquo;</TD></TR><TR><TD CLASS="quote">HEY shamoo; YOU DA MAN!!!!!
WTF!?! you couldnt just have clicked on the link i posted above, the exact same one that shamoo quoted. do you need someone to hold your hand bro
Old Oct 31, 2005 | 01:03 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: (juicyfn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juicyfn &raquo;</TD></TR><TR><TD CLASS="quote">
WTF!?! you couldnt just have clicked on the link i posted above, the exact same one that shamoo quoted. do you need someone to hold your hand bro </TD></TR></TABLE>
some people are super lazy man...hand fed
Old Aug 8, 2006 | 07:43 PM
94bangerEJ1's Avatar
Old Aug 8, 2006 | 08:47 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: DIY install of a JDM ITR/Front End conversion (94bangerEJ1)
Do yourself a favor and weld the supports on please.
Old Dec 11, 2011 | 11:13 PM
Kanekz13's Avatar
pics don't work...
Old Dec 12, 2011 | 02:09 PM
Ef Hatch 34's Avatar
Originally Posted by Kanekz13
pics don't work...
cuz it's a 6 year old thread..
Old Dec 12, 2011 | 08:10 PM
Kanekz13's Avatar
hah, my bad... wish it still works. any updates on da forums? all i can find in da search is youtube videos
Old Dec 13, 2011 | 10:17 AM
JOE_DC4ever's Avatar
Weld it on and paint afterward so you can paint over the welds.
Old Feb 27, 2014 | 03:15 AM
jmoua209's Avatar
i have a question i have the fenders, headlights, bumper, bumper support, hood, but i don't have the radiator support, can i jus use the old one from the regular integra or is it not the same
Old Feb 27, 2014 | 03:25 AM
jmoua209's Avatar
is the radiator support the same as regular acura integra support or is it different from jdm radiator support
Old Feb 27, 2014 | 10:38 AM
cvcrcr99's Avatar
it is not the same. you think all these people who did the swap would have posted that up already.
Old Feb 27, 2014 | 11:16 AM
B_Swapped93's Avatar
if you're asking these questions pay someone else to do it....
Old Mar 1, 2014 | 04:10 AM
jmoua209's Avatar
Default anybody have any jdm/itr parts for sale
I'm looking for any jdm itr bumper support and reinforcement bar also headlight for sale is there anyone selling these items in the 209 area or closer
Old Mar 2, 2014 | 03:45 AM
cvcrcr99's Avatar
hondamarketplace.com
sheekdude
Northeast (Sales)
Mar 18, 2007 12:09 AM
Ls-Turbo
Jul 2, 2005 12:28 AM
Demon R
Feb 25, 2005 10:09 PM
BIGGIDYBOB
Jul 21, 2003 01:16 AM
JDMjames
Jun 27, 2003 08:58 PM
