DIY front toe set ?
Old Mar 14, 2014 | 07:07 PM
B_Swapped93's Avatar
Default DIY front toe set ?
Would simply counting the reads to the jamb nut on the inner rod work ? I'm not being cheap but I replaced my inner/out rods an the car has a bad shake to it.
car has to be driven to a shop for alignment this is a temp fix going for 0 toe
Old Mar 15, 2014 | 05:47 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: DIY front toe set ?
Car shouldn't shake because it needs an alignment, BTW.
Eyeball it. The car has to be on the ground. If the drive to the shop isn't far, you're over thinking it. Get it close and drive off.
Old Mar 15, 2014 | 07:06 AM
tamboo's Avatar
10 Year Member
https://honda-tech.com/forums/acura-integra-type-r-8/diy-r-alignment-quick-method-2631081/
Old Mar 16, 2014 | 06:31 AM
fcm's Avatar
fcm
Old Fart
X2^^^ 94
Old Mar 17, 2014 | 10:14 AM
1ls/vtec's Avatar
dont rely on the thread counting method. I did that and my tires where all out of whack. Like B Serious said, put it on the ground and make sure your steering wheel is straight and eyeball it and adjust the tie rod till your tires are even. Good luck. Hardest part to me was getting that damn dust cover on the inner tie rod/steering rack.
ricoisme26
Apr 7, 2016 04:35 PM
woodenchef
Suspension & Brakes
Jun 20, 2013 09:54 AM
tv_engr
May 20, 2004 04:32 AM
Thasty
Sep 17, 2003 03:33 PM
