Displacement Effects
Old Oct 24, 2003 | 01:58 PM
T3mp3sT's Avatar
Default Displacement Effects
Hi, another N00b question for ya'll. I tried searching for help on this but was rather unsuccessful...
Question is, is there anyway to determind the effects of a displacement boost on an engine other than dyno'ing it?
Went from 1.8L to 2.0L -- B18B1
Any resources i could look at?
Old Oct 24, 2003 | 02:19 PM
thrty8street's Avatar
what do you mean by effects? horsepower? times slips may tell you the difference if you gained any power if thats what you mean.
Old Oct 24, 2003 | 02:22 PM
psychotic_z's Avatar
Default Re: Displacement Effects (T3mp3sT)
There may be some sort of calculator or formula for this, but... you can compare with a B20 motor. B18A/B and a B20 motors are identical in a lot of ways. The only real difference is larger bore (not sure about stroke). Power differences are only minimal, but the B20 carries a lot more torque. Granted, there are other small factors that affect the power and torque levels, like intake manifolds (B20 manifolds have significantly longer runners that favor air velocity & torque), but generally, if you boost displacement, you get more torque and more power. How much of each depends on the rest of your setup.
For the exact power differences, search "B20 power" or something similar. I can tell you I think the B20 carries about 142hp and ~130-135 ft-lbs. I don't know, I'm a nut.
Hope that helps.
Old Oct 24, 2003 | 02:26 PM
SubieDude's Avatar
Default Re: Displacement Effects (psychotic_z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psychotic_z &raquo;</TD></TR><TR><TD CLASS="quote">There may be some sort of calculator or formula for this, but... you can compare with a B20 motor. B18A/B and a B20 motors are identical in a lot of ways. The only real difference is larger bore (not sure about stroke). Power differences are only minimal, but the B20 carries a lot more torque. Granted, there are other small factors that affect the power and torque levels, like intake manifolds (B20 manifolds have significantly longer runners that favor air velocity & torque), but generally, if you boost displacement, you get more torque and more power. How much of each depends on the rest of your setup.
Hope that helps. </TD></TR></TABLE>
yea theres definetely some kinda formula for that...the best you could do is rip apart your motor grab a micrometer and start doing some measurements...have fun doing that...
Old Nov 3, 2003 | 09:11 PM
T3mp3sT's Avatar
Heh I doubt the HP is anywhere NEAR proportional to displacement (obviously--duh)... If i could figure out the curve... hmmm hahaha some performance studies shall follow I suspect.
If anyone has another method, let me know!!
Old Nov 4, 2003 | 04:23 AM
Gerhard_001's Avatar
Default Re: (T3mp3sT)
How about you get it dynoed, as the mathmatical formula is not always dead on because of many variables.
Old Nov 4, 2003 | 08:39 AM
BlueTeg's Avatar
Only accurate way to measure is to dyno it.
It won't be the same everytime.....engine package and tuning will determine how much more power you make w/ a 2L block. Do you already have the block?
sgriffiths
17
Jun 23, 2009 05:17 PM
outtacontrolsol
Dec 21, 2006 09:18 AM
theblkrascal
Dec 15, 2005 08:59 AM
importdays
Dec 5, 2005 03:06 AM
rbr94prelude
Jan 27, 2005 07:52 PM
