Dim Headlights
Old Apr 24, 2003 | 04:18 PM
jensen's Avatar
Default Dim Headlights
Ever since I purchased my 2001 GSR my headlights have been pretty dim. Once I put blue bulbs in them they are even dimmer. Any suggestions?
Old Apr 24, 2003 | 04:22 PM
NeoGSR's Avatar
Default Re: Dim Headlights (SuperJon)
how do the rest of the power accessories work?
alternator? weak battery?
Old Apr 24, 2003 | 05:11 PM
TheGSRGuy's Avatar
Default Re: Dim Headlights (NeoGSR)
Check your alternator.
Blue bulbs won't help dim headlamps....they'll also ruin your visibility (I suggest getting rid of them).
Old Apr 24, 2003 | 05:51 PM
VTECorona's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeoGSR &raquo;</TD></TR><TR><TD CLASS="quote">how do the rest of the power accessories work?
alternator? weak battery?</TD></TR></TABLE>
If your other stuff is dim too and you experience interior lights slightly flickering or anything then you definitely need to check out your electrical system. Start with your battery and check for corrosion around the posts, if the battery looks fine then have your alternator checked out.
Old Apr 24, 2003 | 06:11 PM
DK4200's Avatar
Default Re: Dim Headlights (97RedTegGSR)
i know with some nissan's the grounds are crappy, check and re-ground with new wire if nessesary
Old Apr 24, 2003 | 06:34 PM
ebelp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperJon &raquo;</TD></TR><TR><TD CLASS="quote">Any suggestions?</TD></TR></TABLE>
Yeah, HID's. Or you can get a mulitmeter and test your battery and alternator. Just stop by an Advance Auto Parts or Autozone. They can test them for free.
Old Apr 24, 2003 | 08:29 PM
Integ718's Avatar
Projector headlights normally will seem dimmer than regular headlights. You can try higher wattage bulb but I wouldn't recommend it or just get some HIDs.
Old Apr 24, 2003 | 09:28 PM
jabroni95gsr's Avatar
Default Re: Dim Headlights (Integ718)
Do the 9005 conversion and use the Cool blue Sylvania "upgrade" bulb. Do a search and you'll know what i mean. i did the conversion and it works great.
Old Apr 24, 2003 | 11:35 PM
SonicGSR's Avatar
Default Re: Dim Headlights (jabroni95gsr)
"cheap" aftermarket blue bulbs will kill your visibility, do a comparison test with another Integra.
If its truely dim run the checks mentioned above.
HIDS=Big improvement
Old Apr 24, 2003 | 11:47 PM
GSRaCeRbOI's Avatar
check your grounds and your battery terminals and connections... also the battery posts for corrosion.. have your battery and alternator load tested... other than that.. put back stock bulbs.. the blue bulbs won't help w/ visibility.. they actually lower visability especially in rain and inclement driving conditions..
Old Apr 25, 2003 | 07:04 AM
Default Re: Dim Headlights (GSRaCeRbOI)
i didn't mean replace it with cheap blue bulbs...but the "upgrade" ones that are listed when you go to pep boys to look for a bulb...They are like $10 each.
Old Apr 25, 2003 | 07:10 AM
Muckman's Avatar
Moderator in Chief
Stock bulbs Blue lights Silverstars HIDs
If you cant afford HIDs then do the silverstar conversion or just get the 9006 bulbs, they will last a bit longer. Ive also noticed my lights wil dim at idle, so that may explain the extra dim-ness.
Old Apr 25, 2003 | 07:36 AM
IntEGNYC's Avatar
Default Re: Dim Headlights (Muckman)
Go HID. 4500 - 6000k
Old Apr 25, 2003 | 01:07 PM
jensen's Avatar
Default Re: Dim Headlights (IntEGNYC)
Thank you everyone for the advice. I have checked my voltages and everything is good...I just notice that my lights are way dimmer than other integras with similar bulbs.
I do have a stereo system, but I dont get any interior dimming at all.
I really do want HIDs for sure, but can you guys recommend specific brands / sources? Everyone claims to have great ones, but I'm sure many suck.
Thanks!
Old Apr 25, 2003 | 04:22 PM
VTECorona's Avatar
Philips or Hella (i think hella uses philips ballasts). I also heard catz are good
Old Apr 25, 2003 | 05:08 PM
nek0's Avatar
You might want to get your electrical inspected before even considering to purchase a HID kit. If you have low voltage, it might not help your ballast either & may cause damage.
If you find out what the problem is, hunt for a good 4300K HID's and if not 6000K if you don't mind losing some lumens but it'd be still x2 brighter then stock halogens. Silverstars are good for their price, probably one of the whitest lights I've seen without the blue/purple hints.
Good HID brands. Top of the line would be Bellof ($800-$900) of Japan which is very strict how they distribute their products. Catz is another great company from Japan. PIAA if you can afford their system. (Very expensive for their HID lineup) Next would be companies like HIDS4Less.com and other manufacturers that will backup with more then 5 years of warranty. Trust me you'll get what you pay for. It doesn't matter if you have Philips bulb/ballasts, if you get cheap connectors and harnesses, you'll see your HID die in less then a year when it's supposed to last over 2500 hours of usage.
Old Apr 25, 2003 | 10:19 PM
blitz_teg's Avatar
Ya HID's are the way to go. The only reason blue bulbs seem dimmer is cause they are. Depending on the brand too! If its a cheap brand, the bulbs usually just coated with a blue tint of some sort. thats why they are dimmer even though the wattage is higher. Their are the good stuff too though. But trust me, once u have HID, u ain't gonna stick to no other lighting!
Old Apr 26, 2003 | 03:34 AM
HiRevn's Avatar
Default Re: Dim Headlights (blitz_teg)
I would definitely dump the blue bulbs. I see so many cars on the road that have the HID look color wise, but they are so dim, they might as well just have their park lights on.
If you do decide to go with HID's you may want to check out Trevor at http://www.visualdynamics.ca I got mine off a groupbuy he had last year. for his service too.
Old Apr 26, 2003 | 08:11 AM
Default Re: Dim Headlights (HiRevn)
Lets see....$400 vs. $20 for a 9005 conversion....i'm not saying they perform the same, but the performance doesn't nesc justify the price in my book..
Just to clarify, AGAIN, the "blue" upgrade bulbs that sylvannia makes and which sells alongside the stock replacement bulbs at any autoparts store are pretty good IMO....i understand the silverstars are a bit better, but costs twice as much...Anyway, I was NOT referring to "blue" lights that just look blue or that are sold on ebay/ricer section of the autoparts store....those are junk. With the 9005 conversion, (high beam bulbs fitted into my low beams) and the upgrade sylvannia bulbs...there was a big difference/improvement, for a minimal investment.
Old Apr 26, 2003 | 12:42 PM
JDMTEG2003's Avatar
if u have high beam bulbs in ur low beams, arent they too bright?
Old Apr 26, 2003 | 12:57 PM
Default Re: Dim Headlights (JDMTEG2003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTEG2003 &raquo;</TD></TR><TR><TD CLASS="quote">if u have high beam bulbs in ur low beams, arent they too bright?</TD></TR></TABLE>
No. Do a search for "9005 conversion"
Old Apr 28, 2003 | 07:08 AM
JDMTEG2003's Avatar
did the "9005 conversion" search...ok, jabroni95gsr: i noticed ur from NY too, do the cops ever mess w/u for having brighter low beams on? i'm thinkin bout doin the conversion too...
Old Apr 28, 2003 | 07:28 AM
no. they just look like HID's...but actually less bright...since the low beam bulb pattern is a projector beam, it does not scatter like the low beam bulb...the higher wattage is just projected forward...its an improvement, but not THAT much so that its blinding...just try it, you'll see.
JDMPHILEP91
Jul 2, 2008 08:17 AM
mike9571
Nov 28, 2005 08:42 PM
spicoli
10
Sep 22, 2004 05:45 PM
conesmasher
Mar 4, 2004 08:14 PM
Calavera
Aug 1, 2003 05:30 AM
