Difficulty downshifting--kick down AUTO trans
Old Apr 17, 2006 | 05:40 PM
Integra Integra's Avatar
Default Difficulty downshifting--kick down AUTO trans
I began noticing this lately. My 99 Integra LS has a difficulty/inabillty to downshift, its annoying because at highway speeds it feels like its bogging because its not downshifting/kick down. Anyone know if its common and what can be done?
Thanks
Old Apr 17, 2006 | 05:44 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Difficulty downshifting--kick down AUTO trans (Integra Integra)
That's the nature of having an automatic. Chances are VERY low that there is actually a malfunction in the TCM or the transmission itself.
What are "highway speeds"? If it's anything higher than 65mph, then even if you floor it, many times it's not going to downshift. There are many things that dictate what will happen when you floor the gas.
sunnydeez's Avatar
have u checked you're fluid?
Old Apr 17, 2006 | 05:51 PM
Default Re: Difficulty downshifting--kick down AUTO trans (shamoo)
Yeah I was going 65+ almost 70-75 MPH and then I would floor it to see if it shifted OK and it did very fine but then afterwards it felt like it wanted to shift down or w/e but it was hold steady (the RPM's)
Thanks..
My mechanic also csaid the shift cable possibly needs adjusting because the shiftdown doesnt feel right
Old Apr 17, 2006 | 06:00 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra Integra &raquo;</TD></TR><TR><TD CLASS="quote">My mechanic also csaid the shift cable possibly needs adjusting because the shiftdown doesnt feel right</TD></TR></TABLE>
Hm? Shift cable?
Old Apr 17, 2006 | 06:04 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">Hm? Shift cable?</TD></TR></TABLE>
lol, yeah the ones all automatics have
How much does your "mechanic" Actually know?
How much mileage does your car have anyways?
Has it been beat on much, or any nice neutral rev drops?
Old Apr 17, 2006 | 06:45 PM
Default Re: Difficulty downshifting--kick down AUTO trans (FlatBlackTeg)
It has 80k miles and no neutral drops... what do ya think? It feels like stuck at 70MPH like it wants to downsift but RPms dont drop
Old Apr 17, 2006 | 06:51 PM
Hype-R Stalker
I've only really had one automatic, but it wasn't a teg.
Not really sure though, how far up in speed does it go if you stomp on it from a slower speed?
Like, how far in MPH does it go before shifting into 4th, if you have the gas to the floor.
Old Apr 17, 2006 | 07:04 PM
Well something doesnt feel right I will do a ATF fluid drain + refill w/ ATF Z1 tomorrow see if it improves
Old Apr 17, 2006 | 07:50 PM
Jay J's Avatar
Prince of Zamunda
Try Seafoam ATF flush first
Old Apr 17, 2006 | 07:55 PM
...rohit's Avatar
Default Re: Difficulty downshifting--kick down AUTO trans (Jay J)
might be low motor oil. mine shifts hard and misses a few gears because it eats oil
Old Apr 17, 2006 | 07:57 PM
Benard's Avatar
hmm, im not familiar with honda automatics...but there should be a kickdown cable or throttle valve cable, coming off the throttle body, going to the transmission. This cable lets the valve body know how hard your foot is on the pedal, you could find that cable and try to adjust it..
another thing that might help...Is your overdrive button pressed in on the shifter? just checking...hehe
If this still doesnt fix your problem, i would sugest taking it to a tranny shop, because it could be an issue with your tq converter not locking one to one, or a valve body problem...just throwing some things out...good luck
Old Apr 17, 2006 | 09:06 PM
Desired_Speeds's Avatar
adjust kickdown cable?
Old Apr 18, 2006 | 06:43 AM
Default Re: Difficulty downshifting--kick down AUTO trans (Benard)
I am going to check the fluids today too see how it is and I will probably drain + refill.. Anyone else ever try seafoam ATF Trans Fix?
Old Apr 18, 2006 | 06:32 PM
He adjusted a cable that runs from the thottle body and runs down the lower radiator hose and now it feels much better. Thansk for your help guys
5.4ever
11
Feb 3, 2014 03:30 AM
ahmad-a
Dec 13, 2006 10:00 AM
wompwomp61
Dec 18, 2004 06:29 PM
lphenom
Sep 8, 2004 10:23 PM
suspendedHatch
Apr 25, 2004 03:48 PM
