Differential Preload with tapered bearings
Old Dec 23, 2025 | 08:04 PM
Frogdy's Avatar
Icon5 Differential Preload with tapered bearings
I am currently trying to install a type r lsd (tapered bearings) with 4.7 final drive, ls gearset, into a new b18c bellhousing and case.
I'm having trouble with finding the preload. I'm pretty sure Honda didn't use the preload shims for this but when I just tapped the outer bearing race into the bellhousing a random distance and then fully torqued down the case, I threw in an axle to get a feel for how much force i needed and it felt about right 2.5lbs, maybe more.
So my question is how do I actually set the preload?
I know of the feeler gauge method but what exactly should I be looking for with that and what shim would I need for whatever distance, the exact mm, +- .001mm?
I tried to do this once before as the previous owner didn't set it which broke the open diff's bearing neck and not knowing any better, and also finding a loose bolt in the trans, I wasn't aware of this preload especially since all the videos I watched never mentioned it so this is my second go round and I don't wanna drop more money for another diff.
I'm also just considering taking it to a shop and eating a smaller fee so I don't mess up again.
Old Dec 23, 2025 | 09:04 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Differential Preload with tapered bearings
Is the "New" case/bell housing set up for tapered bearings or the squared single-piece roller bearings ?
Old Dec 24, 2025 | 08:49 AM
Frogdy's Avatar
How is it supposed to be set up? Like the snap ring in the case side bore?
Old Dec 24, 2025 | 06:37 PM
JRCivic1's Avatar
10 Year Member
Community Builder
The installation height is machined differently - the tapered bearing installation uses not only the snap ring style shims, but there is also a very thick washer (the hole in the middle is just slightly larger than the axle input spline) next to the shim. Then the race is tapped into place. If you try to use the wrong parts for any case, you can create massive damage to the case. Does your case still have a VIN plate on it ? If so, you can run the VIN on an Acura parts website and see what type of bearings are used in that case so that you make sure you are doing it right. The tapered bearing/race set up is not clearanced the same way as the 1-piece roller bearings, the former is set by preload (requires a very special torque wrench that reads BOTH directions) in INCH POUNDS, while the latter is checked by feeler gauge for free-play.
SPiFF
Jul 13, 2009 09:57 AM
speeddave
Transmission & Drivetrain
Apr 29, 2009 11:35 PM
577HondaPrelude
Apr 10, 2006 05:23 PM
Mikes01GSR
Feb 20, 2004 08:44 AM
