Differential Case cracked
96 LS Integra Manual transmission
My differential cracked at the drain bolt location. Part of the drain bolt hole broke apart from the case. Now i have a heavy leak from that area. What are my options? I tried to search for a local welder but couldn't find anyone that specializes in aluminum.
So what are my options? Is there replacements just for the differential case? How much work and money would it cost me? etc etc. Need input asap.!
Modified by InTeGrA_bLazEd at 11:05 AM 1/26/2008
differential is what put ur power to the wheel say it between tranny and the axel connection. However differential prices are costly, i would try to find a stock differential to replace it with rather then performance at ur
point.
point.
i understand it's role. The internals of the differential are fine and intact. It's the actual outter casing/housing of the differential that has a crack.
I know those performance differentials don't come w/ a housing. As far as i could tell from pictures it looks like the manual tranny and differential share the same housing. Correct me if i'm wrong.
Would I be able to separate the differential (case and all) from the manual transmission case and just replace the differential alone?
lol same **** with my DA.. differential is cracked from front to back.. water got inside so theres rust in the gears
oh well. If you thinking about getting a new one, few hundred more would get you an LSD
. If not junkyards prolly have one for cheap. Im not a mechanic so i cant tell u how much it is for labor. Any suggestions? Id appreciate it also
alscrx
Transmission & Drivetrain
12
Oct 20, 2009 03:56 PM
alscrx
Jul 30, 2009 04:46 PM
ccivic
Welding / Fabrication
Aug 24, 2005 02:03 AM
persain488
Mar 11, 2003 04:39 PM
