Different main caps
Old Oct 21, 2009 | 07:33 PM
fortillian's Avatar
Default Different main caps
Is there anything negative in buying a block with out main caps and putting the same engine model caps back in? Or do they have to be the ones that came with your specific engine? Its a B18c1 btw.
Old Oct 21, 2009 | 07:43 PM
sabrosa489's Avatar
Default Re: Different main caps
if you buy the motor with out the main caps and used different ones you will have to take the motor to the machine shop for a line hone i belive is the name they use when ever different main caps are used... if you used the original main caps that came with your specific engine you will evoid the cost of the machining from the the machine shop
Old Oct 21, 2009 | 11:23 PM
fortillian's Avatar
Thanks, you just saved me from a headache.
toxictom
Engine Machining & Assembly
Jun 24, 2017 10:28 PM
pettyboy69
Apr 18, 2013 06:09 AM
tamadrummer1120
Feb 2, 2012 01:57 PM
tunerz
Oct 6, 2006 01:26 PM
rmcdaniels
Apr 29, 2005 09:51 PM
