difference in rim manufacturing method?
Old Feb 4, 2004 | 06:36 PM
Loveless's Avatar
Default difference in rim manufacturing method?
what do they mean?
cast
cast mg
forged
spun
ssf
which one is better? and what does stock rims usually use?
Old Feb 4, 2004 | 06:39 PM
99-DC2's Avatar
Default Re: difference in rim manufacturing method? (Loveless)
stock rims are usually cast steel... good wheels are usually forged to make them light and strong...
Old Feb 4, 2004 | 09:35 PM
roadrunner_2k2's Avatar
i believe forged are the best as they are made using liquid metal put in a mold, cast being next as they are cut out of a block of aluminum making it weaker
Old Feb 5, 2004 | 04:23 AM
JimBlake's Avatar
Default Re: difference in rim manufacturing method? (roadrunner_2k2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2-99 &raquo;</TD></TR><TR><TD CLASS="quote">stock rims are usually cast steel... good wheels are usually forged to make them light and strong...</TD></TR></TABLE>Steelies are not cast. Maybe the rim part is rolled, the disk is stamped, & they're welded together. Your lower control arms & brake rotors are cast. See how much different they look vs. steel wheels?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roadrunner_2k2 &raquo;</TD></TR><TR><TD CLASS="quote">i believe forged are the best as they are made using liquid metal put in a mold, cast being next as they are cut out of a block of aluminum making it weaker </TD></TR></TABLE>Cast is made by pouring metal into a mold. Forged are hot-worked & cold-worked; kinda like pressed or hammered while they're hot, but not molten. 'Cut out of a block of aluminum' sounds like billet wheels. The 'block' that a machinist starts from is called a billet.
Old Feb 5, 2004 | 05:29 AM
HYPERION-X's Avatar
Jim Blake is right except for for forged wheels use huge presses that can weigh anywhere between 5000 to 15000 pounds to change the structure of the metal.
melsun_ap1
Honda S2000
12
Sep 23, 2007 07:57 PM
nycludekid
Apr 17, 2007 08:45 AM
lemon_juice
Feb 1, 2007 07:48 PM
Rene M
May 4, 2004 09:46 AM
impulse333
Sep 23, 2003 06:56 PM
