Difference CTR pistons would make
Old Nov 22, 2005 | 07:39 AM
RenzoDaPlayboi's Avatar
Default Difference CTR pistons would make
how much gain would CTR pistons make in a stock b18a?
Old Nov 22, 2005 | 08:13 AM
Kendall's Avatar
Probably not very much (outside of some serious detonation) without some kind of tuning. I'd do P30's instead.
Old Nov 22, 2005 | 08:33 AM
IN VTEC's Avatar
Default Re: Difference CTR pistons would make (RenzoDaPlayboi)
I think the PCT's are kinda heavy. The .25OS slugs are anywhere from 330g to 335g each. A P72-A0 piston in std bore has a mass of about 302g to 303g. Forged pistons are usually sub-300g. The set of 81mm JUN Cosworth pistons I massed were about 290g for a similar +6cc dome to the PCT's.
You can find other, better ways of gaining mechanical compression than just by using a bigger dome. You just have to consider how much in the clearances you're losing to make sure not to go too far.
aris04
Jun 7, 2004 12:03 PM
Type-Rare#1248
Feb 7, 2004 11:01 PM
mugenintegra16
Jun 9, 2002 05:49 PM
