difference between ls axleback and itr axleback?
Old Apr 10, 2003 | 11:11 PM
p1ccoloz's Avatar
Default difference between ls axleback and itr axleback?
can someone fill me in on the difference between ls axleback and itr axleback?
Old Apr 11, 2003 | 04:43 AM
JLange's Avatar
Default Re: difference between ls axleback and itr axleback? (p1ccoloz)
alot of difference, the ITR has way more air flow, a shiny tip thats cut at different angles, i can take pics of my exhaust and send it to you if you please
Old Apr 11, 2003 | 06:03 AM
Ketone's Avatar
I think it flows like 30% better than the Regular integra exhaust, plus it has the better tip
Old Apr 11, 2003 | 08:52 AM
94ls's Avatar
the main diff between these 2 systems is the piping diameter. stock ls piping is between 1.91-2.0" whereas the ITR piping is 2.25" all the way back. The muffler itself is the same design except the ITR muffler is slightly bigger a bit less chambered which allows more airflow, the tip on the ITR muffler is slash cut much like the stock gsr tip. In reference to length, the ls axleback and ITR rear section are the same size. hope that helps
mr_loy
Aug 31, 2009 08:53 AM
dyzryd
May 5, 2005 06:14 PM
BIGGIDYBOB
Jan 30, 2003 11:44 AM
LOwrestling2001
Apr 29, 2002 08:20 AM
CSmith
Apr 5, 2002 06:48 AM
