difference between b18a and b18b clutch?
Old Nov 25, 2006 | 08:16 PM
dmotoguy's Avatar
Default difference between b18a and b18b clutch?
I have a b18a tranny and b18b block, what is the difference between the two clutches and which one is correct to use?
Old Nov 25, 2006 | 08:27 PM
DB1_559's Avatar
Default Re: difference between b18a and b18b clutch? (dmotoguy)
you need the b18a clutch but only if its a 92-93 but i think 94-up will work cause its the same spline but correct me if im wrong and if it a 90-91 you will need a 90-91 clutch
Old Nov 25, 2006 | 08:38 PM
LoseRPunKx182's Avatar
Default Re: difference between b18a and b18b clutch? (jdmboi86)
what year tranny? i believe 90-91 are different from the others while 92+ will work
Old Nov 26, 2006 | 06:20 AM
mymeatb18
Default Re: difference between b18a and b18b clutch? (LoseRPunKx182)
all trannies 92+ use the same clutch, 90-91 use a different clutch smaller spline
Old Nov 26, 2006 | 07:13 AM
projectTeG's Avatar
Default Re: difference between b18a and b18b clutch? (mymeatb18")
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mymeatb18" &raquo;</TD></TR><TR><TD CLASS="quote">all trannies 92+ use the same clutch, 90-91 use a different clutch smaller spline</TD></TR></TABLE>
Old Nov 26, 2006 | 02:27 PM
dmotoguy's Avatar
Default Re: difference between b18a and b18b clutch? (projectTeG)
thanks..
I think its a 93 tranny.. used the clutch and tranny from a b18a the car came with and replaced the block with a 2000 b18b.. it all went together fine..
MantisX
Oct 27, 2008 11:05 AM
chillz03
Aug 9, 2008 01:03 PM
dartonh22
Mar 29, 2008 06:22 AM
mycrx7
May 17, 2005 09:23 AM
.cingham
Mar 16, 2004 09:03 PM
