Determining LS year
Old Jul 2, 2005 | 03:52 PM
H.crx-si
Guest
Posts: n/a
Default Determining LS year
How can I determine what year motor my b18b1 is? I remember someone saying that if the valve cover has a hose running from the side closest to the firewall that it's a newer motor??
Old Jul 2, 2005 | 04:05 PM
thaiphob's Avatar
Nikon!!!
Default Re: Determining LS year (H.crx-si)
on the head, right above the header there are some stamps. there are like 4 circles with numbers and letters in them. i think it was the second one from the left is stamped the year it was cast/made.
Old Jul 2, 2005 | 04:33 PM
H.crx-si
Guest
Posts: n/a
The second one from the left reads like this "8/." so it's a 98 then? It's the only circle that doesn't have two numbers it has a decimal and an eight......
Old Jul 2, 2005 | 05:07 PM
H.crx-si
Guest
Posts: n/a
I read elsewhere that it's actually the circle the farthest to the left that tells the year which means I have a 95 motor.
Old Jul 2, 2005 | 05:14 PM
g3teg97's Avatar
If you unsure on anything about your Integra, chances are you can find out for sure from your Vehicle Identification Number. This guide is valid only for the USA market 3rd generation Integras, other markets and generations may differ.
Example VIN
JH4DB7561WS000001
Separate the VIN like so
J-H-4-DB7-5-6-1-W-S-000001
J= Country of origin
J: Japan
H= Brand
H: Honda Motor Co. Ltd.
4= Vehicle classification
4: Acura Passenger Vehicle
DB7 = Body and engine type.
DB7: 4dr B18B
DB8: 4dr B18C
DC4: 2dr B18B
DC2: 2dr B18C
5= Body and transmission type
3: 2dr 5spd
4: 2dr auto
5: 4dr 5spd
6: 4dr auto
6= Vehicle grade
1: Type R
4: RS
5: LS
6: GS/SE
8: GS-R
9: GS-R w/ leather seats
1= check digit, disregard
W= Model year
R: 1994
S: 1995
T: 1996
V: 1997
W: 1998
X: 1999
Y: 2000
1: 2001
S= Factory Code
S: Suzuka, Japan
000001= serial number
Looking at the example VIN you can tell that the Integra is a 1998 GS 4dr manual.
Taken from Team-Integra.net
Old Jul 2, 2005 | 05:32 PM
H.crx-si
Guest
Posts: n/a
Thanks for all that info but the motor isn't in a integra it's in my ej1 and I'm not 100% sure what year it was.
Old Jul 2, 2005 | 05:36 PM
g3teg97's Avatar
Ahh, misread the post.
My bad
Old Jul 2, 2005 | 05:51 PM
gsrious's Avatar
it's the first circle... not the second one.(assuming you read from left to right)
the first one has the number on it.
Old Jul 2, 2005 | 07:16 PM
tangerinebeast's Avatar
https://honda-tech.com/zerothread?id=1268080
there you go i asked that awhile ago hope that helps you it did for me
Old Jul 3, 2005 | 03:01 PM
H.crx-si
Guest
Posts: n/a
Ok so in that thread people are saying it's the second one from the left that tells the year of the motor and in this thread everyone is saying it's the first on the left. Anybody know exactly which one it is? Seems like everyone claims to know what they're talking about but I'm getting inconsistent answers.
Old Jul 3, 2005 | 04:51 PM
H.crx-si
Guest
Posts: n/a
Somebody must know this.....bump
Old Jul 3, 2005 | 05:33 PM
gsrious's Avatar
like i said... im not joking... go freaken look first.
Old Jul 3, 2005 | 06:01 PM
H.crx-si
Guest
Posts: n/a
Default Re: (gsrious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">like i said... im not joking... go freaken look first.</TD></TR></TABLE>
I did go look. Infact, I wrote each circles numbers down. I just keep hearing conflicting info from people. I'll take your word for it though because it seems like the logical answer to me.
Old Jul 3, 2005 | 06:12 PM
Cliffjumper2's Avatar
Default Re: (H.crx-si)
I find purplegsr to be right a lot about a lot of things here in the integra forum, so go with what he said (at least for the short block, hopefully your head was originally mated to that block) from the other thread:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tangerinebeast &raquo;</TD></TR><TR><TD CLASS="quote"> what is the number under the b18b1 on the block</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">
That is the block id #, you should be able to tell by the first number what year it is. For a b18b, if it starts with 1, it will be 94, 2=95, 3=96, 4=97, 5=98, 6=99, 7=00, and 8=01.</TD></TR></TABLE>
and he also sounds right regarding the head:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">it's the first circle... not the second one.(assuming you read from left to right)
the first one has the number on it.</TD></TR></TABLE>
1DayIllBFast
Apr 16, 2009 04:56 PM
Frost7177
Apr 6, 2009 06:27 AM
civictype-r
Mar 7, 2007 03:12 PM
JapJunkie
Nov 20, 2003 07:17 PM
