Defeative clutch?
Old Sep 11, 2006 | 02:22 AM
JFG Kevin's Avatar
Default Defective clutch?
Is there a such thing as a defeative clutch? I have a pretty new ACT clutch that ive used for maybe 10k, sometimes when i depress it at high rpms, it wont release the clutch fo some reason...Would that be a clutch problem or a master cylinder problem? Also when i'm parkin the car, if i switch from R and 1st alot it gets harder and harder....What does that mean?
Modified by aznstyler119 at 4:55 AM 9/12/2006
Old Sep 11, 2006 | 09:27 AM
DC2 Mang's Avatar
Default Re: Defeative clutch? (aznstyler119)
is your fluid low?
mine did the same thing and it was just my fluid that was low the whole time
Old Sep 11, 2006 | 09:43 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I don't know what defeative means
Old Sep 11, 2006 | 09:50 AM
DC2 Mang's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know what defeative means </TD></TR></TABLE>
im assuming defective?
Old Sep 11, 2006 | 12:36 PM
Leo C's Avatar
Night Owl
Default Re: (DC2 Mang)
Put some carboard under your trans. and see if the slave cylinder is leaking. Also check along the firewall behind the dash near the clutch pedal ( master cylinder) for leaks. Then again, you might just be low on clutch fluid.
Old Sep 11, 2006 | 02:46 PM
Community Builder
If the clutch fluid is low, it will feel like there is a ton of free play at the top of the pedal travel. But if it's low, then it's probably leaking somewhere anyway. Mine was leaking from the MC, but I went ahead and replaced both the master and slave, since they both had almost 230K miles on them.
Old Sep 11, 2006 | 06:11 PM
prada_G's Avatar
already try bleeding the system?
Old Sep 11, 2006 | 07:54 PM
JFG Kevin's Avatar
Default Re: Defeative clutch? (prada_G)
bleeded....full fluid....same problem...no leaking.....can't figure out the problem...
Old Sep 12, 2006 | 04:48 PM
JFG Kevin's Avatar
BUMP....i also put in a new release bearing, i just took apart my motor and the clutch seems fine...why was i having this problem?
slow88crx
Oct 16, 2007 05:11 PM
meagainsttheworld
Aug 30, 2006 05:53 PM
crdcz03
May 5, 2005 06:43 PM
Jack Black
Feb 18, 2005 11:30 AM
type_sml
Aug 23, 2002 12:53 PM
