DC2 Integra Lowered
Old Aug 23, 2007 | 04:34 PM
wildcat98's Avatar
Default DC2 Integra Lowered
I just lowered my 1996 Honda Integra (JDM)
I used the following:
1. Apexi World Sport Coilovers
2. Ingalls Camber Kit
3. Replaced the stock bump stops with some teflon ones
4. I went with smaller tyres as well .. from 205/50/15 to 195/50/15
I also had to bend away the lip under the fender to allow the uca to pass.
After driving around for a couple days i reilized that that my UCA was hitting my strut tower, so i opted to raise the car by two turns on the coilover spindles
Alot of persons are against the usage of camber kits but i had no choice as it the new height it had induced over 2 degrees of camber
The pics below are with the bigger tyres; when i get a chance ill take with the smaller tyres
Please post what you think !!!!!
Old Aug 23, 2007 | 04:52 PM
lsvtek's Avatar
Default Re: DC2 Integra Lowered (wildcat98)
looks pretty sick dude
Old Aug 23, 2007 | 04:54 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: DC2 Integra Lowered (LSintegra4)
Looks really good, in my opinion, even if it's been done a lot, some Blades would really set it off...
Old Aug 23, 2007 | 04:58 PM
nA_Gsr303's Avatar
Default Re: DC2 Integra Lowered (Project95LS-VTEC (G))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project95LS-VTEC (G) &raquo;</TD></TR><TR><TD CLASS="quote">Looks really good, in my opinion, even if it's been done a lot, some Blades would really set it off...</TD></TR></TABLE>
eh Looks fine dont add blades
Old Aug 23, 2007 | 05:00 PM
wildcat98's Avatar
Can u post a pic of the blades !!!!!
Old Aug 23, 2007 | 05:08 PM
crispy93's Avatar
looks pretty damn good if you ask me
Micha's Avatar
FAILWGN
You need a front Camber kit that will actually move the mounting point outwards. Something like skunk2 or Blox I think.
Old Aug 23, 2007 | 05:12 PM
wildcat98's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSintegra4 &raquo;</TD></TR><TR><TD CLASS="quote">looks pretty sick dude</TD></TR></TABLE>
thanks
Old Aug 23, 2007 | 05:13 PM
wildcat98's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crispy93 &raquo;</TD></TR><TR><TD CLASS="quote">looks pretty damn good if you ask me </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nA_Gsr303 &raquo;</TD></TR><TR><TD CLASS="quote">
eh Looks fine dont add blades </TD></TR></TABLE>
Thanks All
Old Aug 23, 2007 | 07:14 PM
I AM WEASEL's Avatar
Looks good, would look better with a front lip though
Old Aug 23, 2007 | 07:16 PM
Usagi Yojimbo's Avatar
From: Dont say my car is topless say the titties is out
Default Re: (JDM se-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM se-R &raquo;</TD></TR><TR><TD CLASS="quote">Looks good, would look better with a front lip though</TD></TR></TABLE>
x2.
Old Aug 23, 2007 | 08:21 PM
GSR in progress 96's Avatar
* B A N N E D *
Looks good
Old Aug 23, 2007 | 08:44 PM
vietnamezerice's Avatar
Default Re: DC2 Integra Lowered (GSR-(soon to be)T)
looks naked without a lip
Old Aug 23, 2007 | 08:48 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wildcat98 &raquo;</TD></TR><TR><TD CLASS="quote">I just lowered my 1996 Honda Integra (JDM)
Please post what you think !!!!! </TD></TR></TABLE>
2 degrees negative camber? That's within stock alignment settings for a GSR. Camber doesnt wear tires, yo. Toe does.
Remove the camber kit, and put your stock tires back on. You really shouldnt have any problems with the UCA hitting the strut tower at that height.
Old Aug 24, 2007 | 02:03 AM
TastyDragon's Avatar
Default Re: DC2 Integra Lowered (B serious)
call me a newb but what are uca's and bump stops? my dc is lowered pretty good too even lower than that and i tend to hit **** and scrape stuff. im on 205/50/15 too.
Old Aug 24, 2007 | 03:51 AM
wildcat98's Avatar
Default Re: DC2 Integra Lowered (vietnamezerice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnamezerice &raquo;</TD></TR><TR><TD CLASS="quote">looks naked without a lip </TD></TR></TABLE>
Lip ordered ... waiting to be painted .... will post updated pics..
Old Aug 24, 2007 | 03:52 AM
wildcat98's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Usagi Yojimbo &raquo;</TD></TR><TR><TD CLASS="quote">
x2. </TD></TR></TABLE>
Front lip on its way .... stay tuned
Old Aug 24, 2007 | 03:59 AM
wildcat98's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
When i went to the alignment stand 2 degrees is outside of the stock alignment settings ...but it was aligned and the toe set to zero in the front and added a little in the rear
My car is actually a Honda Integra SIR (JDM Spec) and i used the settings for the Acura Integra GSR ... which should be just about the same.
ill try and take pics of the strut tower .... the paint started to chip in the engine bay at the impact point of the UCA.
PS. I using stock UCA's
Old Aug 24, 2007 | 04:02 AM
wildcat98's Avatar
Default Re: DC2 Integra Lowered (TastyDragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TastyDragon &raquo;</TD></TR><TR><TD CLASS="quote">call me a newb but what are uca's and bump stops? my dc is lowered pretty good too even lower than that and i tend to hit **** and scrape stuff. im on 205/50/15 too.</TD></TR></TABLE>
UCA...... Upper contoller arms
Bump stops....... They are teflon or polyurethane bushings that are put on the struts that prevent the prevent them from hitting the strut mounts when fully compressed
Old Aug 27, 2007 | 06:17 PM
it'll look really nice after the lip installation
Old Aug 27, 2007 | 06:38 PM
BDA9's Avatar
really nice.
Old Aug 27, 2007 | 06:56 PM
cornflake-dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote"> Camber doesnt wear tires, yo. Toe does.</TD></TR></TABLE>
lol?
Old Aug 27, 2007 | 07:37 PM
wildcat98's Avatar
Update .......
I have put on smaller tyres since those pics above from 205/55/15 to 195/50/15
The Chin spoiler has been sprayed and will be installed tomorrow
pics to come soon.
Old Aug 27, 2007 | 07:39 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: DC2 Integra Lowered (cornflake-dc2)
Blades sitting still:
Blades moving:
Old Aug 27, 2007 | 08:00 PM
wildcat98's Avatar
Default Re: DC2 Integra Lowered (SlammedDC2)
Looking ohh so good ..... I want my car to look clean like that one day ...
They are only that a few of those blades in jamaica
