dc window auto down reprogram??
anyone know what the steps are to reprogram the driver window auto down function on my 95 ls. i took the door panel off the other day and i just noticed the auto down wont auto down anymore?
ive done this before. you hold it all the way down and keep holding it. here are the steps again. put the window up and take the key out. now hold the button all the way down and turn the key on. keep holding it till the window is all the way down then let go. bring the window back up and see if the auto feature works.
ok, i tried all that and its not working. are you sure this is for a dc teg? i even tried all the ways that nissan/infiniti's reprogram but i cant remember any of the honda steps.
I thought the Auto down function was a mechanical property of the window switch? When you press the switch all the way, it stays in that position and then you can hear it click back when the window is all the way down.
OP the Helms manual lists 3 different possibilities for troubleshooting the auto down function not working. It would be difficult now, so you really need the manual, but there are several different continuity and voltage tests it lists to run to try to isolate the problem of the switch not working in the Auto position. Could be a poor ground, blown fuses, bad power window relay, bad window motor, etc.
you might be right but it is computer operated also. try to listen for the click on a volvo or a bmw. you will never hear it. you have to program it. he just unpluged it and pluged it back in to do his door panel. i doubt theres anything mechanically wrong. unless it wasnt working before.
Yes, actually there is an additional mechanical switch underneath the driver side window switch that holds in the down position until the window is all the way down. I just tried it, and with my finger touching the switch I could feel it click back to the center position when the window is down. Helms wiring diagram confirms it.
On a side note, most manufactures in the past 10 years use a device (believe its call a PolyDevice) that is basically a relay that "breaks" when the motor binds up. Thus, this circuit/relay senses when the window is fully open/closed and kills power the motor. Also, most auto windows now use a relay that is not built into the switch as those often break (just as the case w/ the Integras).
no it DID work before, just not since i unpluged it. theres not a separate fuse for the auto function aside from the normal up/down is there?? ive tried the steps above now several times and still no go.
what really gets me, is that i own two integra's and my 94 that iv'e owned for 7 years now has had the door panels off dozens of times and i have NEVER had to reprogramed the auto function on it.
im kinda confused as to what you are talking about when you say there is a "second switch under the driver switch" that goes back to the middle when the window is all the way down. doesnt the switch go back to the middle as soon as you let go of it?? are you talking about a relay in the switch panel?
and as far as newer windows using relays to know when the window is up, isnt entirely accurate. they will use a high resistance breaker/relay to roll the window back down as an anti pinch feature when they "see" resistance, but they use a sensor in the motor that counts the rotations/position of the motor (similar to a cam or crank angle sensor) to know what position the glass is at. this is all usualy contained in the motor's housing and when they go bad usually the other window function act funny also so the whole thing gets replaced, which i do on g35's at work on a pretty regular basis.
but thats all beside the point of me not being able to reprogram my window that was working fine untill i unplugged it.
Indeed the wiring diagram in the Helms shows it as a second contact position for the Auto Down function.
hey just wanted to point out that my auto down hasnt worked for about 2 years and today i took my door panel off, removed the window switch, opened up the housing and cleaned it out. there was alot of crud in there. i then plugged it back in and now my auto down works again. didnt even have to "re-program" it. for those of you whose switches dont work, try cleaning it out. years of dust and other foreign particles can cause the switch's auto down feature to not function by obstructing the contacts for this feature.
Just signed up to the forums to say thanks for this post. (nothing like bumping a 6 year old post!)
I had my DC5 into the auto-electrician to replace the starter motor, and when I got it back the drivers window auto function was no longer working. I just tried your 'hold down auto open while turning key on and let it open all the way' trick and although it didn't work the first try, it worked after a couple of tries (I actually started with it open and held down auto close, turned on key, held till it was shut, and then it started working after turning key off and back on again).
Anyway thanks for the tip, saves me an argument with the auto-electrician and a trip back to the shop for them to fix it.
Thanks
Matthew
Thanks
Matthew
Thanks
Matthew
Thanks
Matthew
kchungb17a
Feb 15, 2010 07:57 AM
david90
May 29, 2004 04:22 AM
