dc jdm question?
Old Sep 12, 2005 | 11:18 PM
allmotorek8's Avatar
Default dc jdm question?
i heard that if u throw a jdm front end on a usdm dc u got to get the radiator support welding is this tru or bullshit? i thought the jdm radiator support bolts on and there is no need for welding is this theory tru? if i was gonna throw a jdm front end on a dc?
Old Sep 12, 2005 | 11:20 PM
LSvtec03's Avatar
Default Re: dc jdm question? (allmotorek8)
yes, you have to weld it on.
Old Sep 12, 2005 | 11:24 PM
Kendall's Avatar
You can get away with only welding on the top half if you want, but this will require a little bit of cutting.
Old Sep 13, 2005 | 01:25 AM
:jdmshmaydm:'s Avatar
Default Re: (Kendall)
The radiator support does bolt on to mounting holes in the DC chassis. However at that point after it's lined up, you really REALLY should weld the spot welds back together.
Old Sep 13, 2005 | 03:56 AM
Default Re: (Gatecrasher21AF)
ight thanx guys i just wanted to clear that up cuz i never new i had to weld anything?
bump
Old Sep 13, 2005 | 04:10 AM
JDMoMo
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gatecrasher21AF &raquo;</TD></TR><TR><TD CLASS="quote">The radiator support does bolt on to mounting holes in the DC chassis. However at that point after it's lined up, you really REALLY should weld the spot welds back together. </TD></TR></TABLE>
NOT TRUE. Sorry man.....
Here's my post on JDM Conversion - How to instructions with full pictures. Step by step...
https://honda-tech.com/zerothread?id=1346217
It has helped a lot and hope it helps you too man.
Old Sep 13, 2005 | 07:41 PM
Default Re: (JDMoMo)
thanx dawg
Old Sep 13, 2005 | 07:49 PM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMoMo &raquo;</TD></TR><TR><TD CLASS="quote">NOT TRUE. Sorry man.....
It has helped a lot and hope it helps you too man. </TD></TR></TABLE>
that is half true and half not true. half true in that you CAN get away with NOT welding it on, but once you start taking turns, you're going to feel it if not see it.
Not true in the fact that I've WATCHED someone ( over a period of a month ) replace a radiator core support on a eg hatch without re-welding the new one on.......later, when he tried to do an oil change, he decided to use the jack point located underneath the radiator core support.......I watched part of the front end starting to rip right off the car ........then again, maybe he just did a **** poor job of puttin the rcs back on But with that in mind....people telling you to weld it back on could be coming from a safety standpoint. Afterall......better to be safe than sorry. I had the body shop weld mine in.....I wasn't going to risk anything.
Old Sep 13, 2005 | 08:35 PM
Default Re: (Naruto)
thas what ima do ima have a bodyshop weld mine
thanx everyone for info
sikciv666
Dec 1, 2012 06:08 PM
crimsonv4mpire
Jan 21, 2009 01:15 PM
98GSRDC2
Mar 6, 2008 06:56 AM
riceball777
Sep 29, 2006 06:01 PM
kaj
Oct 30, 2005 07:23 AM
