Dang problem...HELP!
Old Jul 12, 2004 | 06:01 PM
sleepin91teg's Avatar
Default Dang problem...HELP, car wont start after head install...
so i got my cams, springs, retainers and head work, all done...try to start it, and its rolling over fine...so im glad everything is rotating properly...im getting air then since the valves are opening and i watched my fuel pressure guage rise from 0 to 40 i beleive its at right now...so i have fuel too...but spark...hmm how do i know if im getting spark? im not sure yet...i dont think my distributor is screwed up, cuz the motor sounds "in time" not like the "out of timing" thump thump thump...so what could it be...i triple and quad checked all electronic conections...and my lil bro and my best friend helped me too...so what should i check??? HELP....Thanx
Modified by sleepin91teg at 10:35 PM 7/12/2004
Old Jul 12, 2004 | 06:05 PM
Default Re: Dang problem...HELP! (sleepin91teg)
HELP...BUMP
Old Jul 12, 2004 | 06:16 PM
Old Jul 12, 2004 | 06:34 PM
I did some searching...and found out some of this...
1) Check fuel pump...if it primes then the main relay may be bad...
2) Replace fuel filter
3) Crank with throttle open, possibly flooded
4) Jump start or Push start
Any thing else would be awesome...im thinking maybe its my main relay...where is this located? 1991 acura integra gs....and how much do these cost? is this a dealership item only...or does autozone and napa carry them?!
Old Jul 12, 2004 | 07:08 PM
Some one?!
Old Jul 13, 2004 | 03:39 AM
Morning Bump
Old Jul 13, 2004 | 09:54 AM
Noon bump
Old Jul 13, 2004 | 11:25 AM
Sack Master's Avatar
You'll know if fuel is going in there. You can smell it. Take a plug wire out and hold it to one of your acorn nuts on your valve cover and see if its throwing spark. It will jump, probably not much if its a stock ignition but you should be able to hear or see if its sparking.
Old Jul 13, 2004 | 12:57 PM
alfee's Avatar
Default Re: Dang problem...HELP! (Sack Master)
check the distributor/rotor/cap and ground wires...
Old Jul 13, 2004 | 01:30 PM
Default Re: Dang problem...HELP! (alfee)
Gonna go check stuff right now...thanx guys...
Old Jul 13, 2004 | 02:03 PM
Default Re: Dang problem...HELP, car wont start after head install... (sleepin91teg)
Just checked for spark...and i have no spark on any of the 4 plugs...ECU fuse is out...
Old Jul 13, 2004 | 02:23 PM
I lied...the plugged the ECU fuse in...and i have spark...so im guessing its fuel...right? Not getting fuel...but the pump primes, and my FPR guage shot up when i primed it...soooo what now?
Luke 91 ef
Jan 24, 2013 10:40 AM
95PreludeNAed
Jan 10, 2012 04:09 PM
Eg6Matt
Oct 23, 2009 06:34 AM
jury
Jan 1, 2007 10:57 AM
pbizzlegsr
Aug 27, 2004 08:55 AM
