Da wit nitrous
Old Sep 10, 2005 | 05:03 PM
RenzoDaPlayboi's Avatar
Default Nitrous for 91 DA
i was wondering how much a 75 shot of nos would cost me...and if it was safe on my stock motor...i just want it for fun...im not gonna spray the **** out of my motor or anything...i just want it for once in a while
Modified by RenzoDaPlayboi at 7:10 PM 9/10/2005
Old Sep 10, 2005 | 05:25 PM
Default Re: Da wit nitrous (RenzoDaPlayboi)
Old Sep 10, 2005 | 06:56 PM
Finger Lickin' good's Avatar
ya just for when your racing?
Its pricy in the long run. Save up a grand, get a wet system.
Old Sep 10, 2005 | 07:00 PM
Default Re: Da wit nitrous (Finger Lickin' good)
so get a 75 shot of wet???
Old Sep 10, 2005 | 07:30 PM
DAguyLS's Avatar
on a 91 DA, with....i'm guessing over 150k? I wouldn't choose a 75 shot of nitrous on a stock high mileage motor, at least if you want to continue using the car.
Old Sep 10, 2005 | 07:46 PM
98b18black's Avatar
Default Re: (DAguyLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAguyLS &raquo;</TD></TR><TR><TD CLASS="quote">on a 91 DA, with....i'm guessing over 150k? I wouldn't choose a 75 shot of nitrous on a stock high mileage motor, at least if you want to continue using the car.</TD></TR></TABLE>
Neither would I....
Old Sep 10, 2005 | 10:08 PM
Default Re: (98b18black)
my car got 125xxx miles
Old Sep 10, 2005 | 10:18 PM
Rajin's Avatar
Default Re: (RenzoDaPlayboi)
Don't do it, save your money for something more impressive.
Old Sep 10, 2005 | 10:21 PM
DA9ReMiX's Avatar
Default Re: Nitrous for 91 DA (RenzoDaPlayboi)
... nos =
Johnny_Rocket's Avatar
Default Re: (Rajin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rajin &raquo;</TD></TR><TR><TD CLASS="quote">Don't do it, save your money for something more impressive.</TD></TR></TABLE>
Old Sep 10, 2005 | 10:22 PM
Rajin's Avatar
Default Re: Nitrous for 91 DA (DA9ReMiX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9ReMiX &raquo;</TD></TR><TR><TD CLASS="quote">... nos = </TD></TR></TABLE>
n2o. Don't get it, worthless to have to refill it.
Old Sep 10, 2005 | 11:30 PM
BlackDAy's Avatar
Default Re: Nitrous for 91 DA (Palmy Blue)
i was running a 75 shot w/a Venom VCN1000. it would cut off the flow of nitrous if you started to run lean. The system pulsates ur injectors so that you have adequate fuel. I had alot of fun with it. motor (ls) had 130K. it hauled some ***. Then i put a 50 on my b16 before i got a turbo. It is a pain in the *** to go and fill up the bottle, and spend 50 or so $ each time. I would just save up and get a turbo or something...
Old Sep 12, 2005 | 05:01 PM
ej8's Avatar
ej8
Default Re: Nitrous for 91 DA (BlackDAy)
I shoot 50shot on a 155k 91 da, no problems. If the motor is healthy and its tuned right you shouldnt have a problem, even with a 75 shot
Old Sep 12, 2005 | 05:09 PM
ebp_dc2's Avatar
do a compression and leakdown test that should help u figure out if ur car can handle it...id say do it if all goes well!
Old Sep 12, 2005 | 06:34 PM
Liquid Ice NF's Avatar
Look into "Cry O2" it'll be safer on your motor, and alot cheaper 2 fill, since it is just co2. the gain isnt anywhere near a 75shot of nitrous, but it is still pretty decent i have heard. Complete kits go for around $270, and it is set up just like a nitrous kit. All this kit does, is greatly cool the intake charge = more power.
alot of people bash on cryo2, but for $270, u cant go wrong. you can always sell it if it doesnt work out.
Old Sep 12, 2005 | 07:46 PM
ej8's Avatar
ej8
Default Re: (Liquid Ice NF)
CO2 injected into the engine will starve it for air
Old Sep 12, 2005 | 08:50 PM
Muckman's Avatar
Moderator in Chief
Just run a 200 shot and get it over with.
Old Sep 12, 2005 | 08:58 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: Nitrous for 91 DA (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Just run a 200 shot and get it over with.</TD></TR></TABLE>
Old Sep 13, 2005 | 12:06 AM
ProjectLSVTEG's Avatar
Default Re: (Palmy Blue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Palmy Blue &raquo;</TD></TR><TR><TD CLASS="quote"> it doesnt actualy go into the engine it goes to a "bulb" on the intake piping which cools the air, they also have kits to cool the fuel system also...</TD></TR></TABLE>
10-4 to that, i looked into it.... sisnt seem worth the cost
and as for nitrous, never call it NOS, please for christs sake! But I had a 75 shot on my 95 LS 140K... and it was fine after i took it off... ran about 6 bottles thru, and realized I was over halfway into the cost of a turbo kit, for not nearly the same amount of horsepower. Save the money for a turbo.
And if nitrous is done right, it won't be detrimental (SP?) to the engine. Just make sure you know the ins and outs.
Old Sep 13, 2005 | 05:40 AM
thank you. it is pretty ideal for those hot days..
Old Sep 13, 2005 | 01:11 PM
Mr. Self Destruct's Avatar
***Prepares fire extinguisher...***
I'll be the first to say screw the turbo, screw saving up your money, and just get the nitrous kit.
I have owned three turboed Hondas, all three of the kits I put together myself. A decent kit is going to run you about $1300-1500 if you don't skimp out on anything, which you shouldn't do anyways. Now you'll have your turbo and you'll be boosting 6-7 lbs which will net you about 65 HP and ~40 Lb/Ft. Also you'll notice your gas gauge going down rapidly since your a turbo noob (a fact, not an offense)...
Now, if you instead opt for, say a 75 wet kit, which you can get just about anywhere for arou $500, you'll be getting 75HP and ~70 Lb/Ft as well.... Everyone knows a 100 shot nitrous car will absolutely rip a 10 psi turbo car a new ******* (this is assuming the cars are the same chassis, same engine, blah, blah, blah...) Also, you won't be wasting nearly as much gasoline, 'cuz you won't be in positive pressure land all the time. $40-$50 dollars a pop seems like a lot, but really it's not. Considering the turbo kit cost you $1000 more than the nitrous kit, that's worth about 20 bottles, which should last you years, unless you are just a spastic nitrous user.
So, spend $1500 and get less power and shitty gas mileage, or spend ~$500 and have more power, no need to mess with hours and hours of tuning along with the rest of the troubles that come with turboed Hondas, and save a little gas...
Old Sep 13, 2005 | 01:19 PM
B18C_DD's Avatar
Default Re: (ej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8 &raquo;</TD></TR><TR><TD CLASS="quote">CO2 injected into the engine will starve it for air</TD></TR></TABLE>
Old Sep 13, 2005 | 03:47 PM
rkrone's Avatar
................turbo...................
Old Sep 13, 2005 | 04:03 PM
txracer's Avatar
Default Re: Nitrous for 91 DA (rkrone)
if i was looking for some big gains in power, id go turbo. and aslong as you stay out of boost when normal driving ive heard of people getting pretty decent gas milage..
Old Sep 13, 2005 | 07:21 PM
Default Re: Nitrous for 91 DA (txracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by txracer &raquo;</TD></TR><TR><TD CLASS="quote">and aslong as you stay out of boost when normal driving ive heard of people getting pretty decent gas milage.. </TD></TR></TABLE>
Oh, I agree... but you and I both know first timers don't like to stay out of boost. And noob settups are usually untuned ro badly tuned as well, so that depletes even more fuel.
