DA water pump replacement
Old Feb 5, 2010 | 07:37 AM
dalejrfan88's Avatar
Default DA water pump replacement
I have been leaking water for atleast 2 weeks now and last night i figured out that it was coming from near the crank pulley so i suspect its the water pump but i searched and also found it could be some O ring? Anyway if it happens to actually be the water pump i guess i should go ahead and replace the timing belt, tensioner and the oil pump while im in there. Would it be better if i used the newer/vtec water and oil pumps? Also is there anything else i should replace while im in there?
97_EX_in_NC
12
Mar 7, 2018 07:17 AM
B00sted Eg2
May 7, 2009 01:34 PM
Mr_Moos
Jun 24, 2007 10:04 PM
yaaj1320
Mar 3, 2007 08:53 PM
tominos
Sep 10, 2004 08:38 PM
