da suspension interchangeable with...?
Old Dec 16, 2006 | 11:06 AM
vice's Avatar
Default da suspension interchangeable with...?
what other cars' suspension will bolt into a DA? i thought DA's were the same as EF and CRX but then some guy said he used a DA shock on his DC. whats right?
Old Dec 16, 2006 | 11:37 AM
AllMotorDan's Avatar
DA, DC, EG all the same. springs are also the same but may vary for spring rates and drops since the weights of the cars are different. my best advice is to order what is for your car
Old Dec 16, 2006 | 04:00 PM
95 integra's Avatar
Default Re: (AllMotorDan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorDan &raquo;</TD></TR><TR><TD CLASS="quote">DA, DC, EG all the same. springs are also the same but may vary for spring rates and drops since the weights of the cars are different. my best advice is to order what is for your car </TD></TR></TABLE>
Not true, the DA has the radius arm vs the 3pt lower control arm. The older 88-91 civics are on the same suspension as the 90-93 integras. I've heard you can use shocks/springs for the 94-01 on the 90-93 but I dont have any personal experience on that.
90-93
http://www.acuraparts247.com/c...0.gif
94+
Old Dec 16, 2006 | 07:18 PM
youknowimwhite's Avatar
Default Re: (95 integra)
i tried to put 00 gsr shocks on my da but wouldn't fit because the lower a-arms on the da's are too small
Old Dec 16, 2006 | 08:54 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (youknowimwhite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youknowimwhite &raquo;</TD></TR><TR><TD CLASS="quote">i tried to put 00 gsr shocks on my da but wouldn't fit because the lower a-arms on the da's are too small</TD></TR></TABLE>
Sounds like they don't fit
As far as I know, EG and DC are the only 2 that interchange but I'm sure something else will fit something else.
Old Dec 16, 2006 | 10:40 PM
Tchleung's Avatar
The older EF/DA suspension has the smaller diameter strut bodies. To run EG/DC struts, you need the EG/DC lower drop forks as the DA ones are too narrow. The height of the rears are also different from my experience. I run the EG kit on my DA
Old Dec 17, 2006 | 04:50 AM
Bri123's Avatar
I know the rear control arms from a DC will fit the DA. I did forget to mention that the Front struts will no fit unless you use DC Forks. my bad for not being elaborate. - AllMotorDan
.Thomas
Suspension & Brakes
Dec 11, 2011 12:10 AM
nigelperera
Suspension & Brakes
Feb 14, 2007 02:43 PM
gutted-dx
17
May 18, 2005 11:22 AM
b18hatch
Mar 16, 2002 08:03 AM
