DA problems need help!
Old Jan 22, 2010 | 06:35 PM
DAfreak02's Avatar
New User
Default DA problems need help!
Whats up guys,
Everytime i step on it the car it feels like its hitting the rev limiter at 4500 rpm and i have to change gears. It happens every gear. also at the same time i step on it the rpm gauge starts jumping everywhere! Iv change the Igniter and it was working fine for 30 till it went bad! I changed the Dizzy cap and was work great till it went to crap! As well i check the engine light and got code 10 and 17! I checked online to see wha code it was and came out that it was the speed sensor and Intake air tempersure sensor with i change the i.a.t.s.! I have a feeling it could be the complete dizzy or the ecu! the reason i say ecu cuz water leaks under the dash where the ecu is! Dose anyone know what it could be???
Thanks!
Old Jan 23, 2010 | 03:35 AM
APCXxstovetopxX's Avatar
Default Re: DA problems need help!
grab a ecu from the junkyard for cheap and swap it to see if it fixes it
Old Jan 23, 2010 | 09:27 PM
pinkda9's Avatar
maybe change out your throttle body, Ive had that issue before its worth a try.
Old Jan 23, 2010 | 10:16 PM
HondaTom87's Avatar
I just had very similar problem and it came out to be a bad injector ground wire... it was slightly pulled out from the clip...
crx88fast
Mar 22, 2005 02:30 PM
msrrex
Nov 2, 2003 10:14 AM
