DA problems need help!!!! =)
Old Jun 27, 2007 | 11:39 PM
spgcuantik's Avatar
Default DA problems need help!!!! =)
well i just bought a 93 integra LS, the girl i bought it from said that the car starts but only after the CEL light goes off which is like 10-15 minutes after (fuel pump primes), sometimes the car doesnt even start so im thinking the main relay, well i go to my honda dealer and buy the main relay plug it in same thing... so i try to smell around the engine bay to see if i can smell gas but nothing, my brother turns the ignition to the first click and nothing, what i hear sounds like a ground is loose or loose wires touching somewhere in the engine bay, i have no idea what it is but i need to get this car started it is my only way of transportation for now
Old Jun 28, 2007 | 02:09 AM
spgcuantik's Avatar
upppppppppppppppppp
Old Jun 28, 2007 | 08:22 AM
PACT man's Avatar
Default Re: (spgcuantik)
Sounds like a common problem with the DA's, I had the same problem, and just like you replaced the main relay and checked and cleaned all the grounds involved. Ended up being the computer which I know a couple other people with DA's also just like me would needed to replace the computer to fix that problem.
Old Jun 28, 2007 | 09:24 AM
loudassVTEC's Avatar
Default Re: DA problems need help!!!! =) (spgcuantik)
Can you hear the fuel pump?? If not, disconnect the fuel return line on the fuel pressure regulator, and have a buddy click the key to ON, and see if fuel flows from the hose. If you've got flow, you know its not the pump. Check and clean your ground connections...all of them. Does the car crank at all? Or is it cranking, but not firing??
Old Jun 28, 2007 | 11:36 PM
spgcuantik's Avatar
well i talked to the girl today, she said that her dad replaced the ECU!!! so i pulled it today and sure enough it said remanufactured ECU it had stickers all over the ECU, they bought it form ebay for 30 bux in 2000, so ima try a new ECU 2mrrw hopefully itll start thx guys
Old Jun 29, 2007 | 11:25 PM
spgcuantik's Avatar
upppppppppppppp
Old Jun 30, 2007 | 06:22 PM
its past tomorrow...did the other ECU work??
Old Jun 30, 2007 | 08:33 PM
spgcuantik's Avatar
expletive i cant find a ECU!!!!!!!!!! gonna go to junkyard monday! im praying it starts fukkkk
Old Jul 1, 2007 | 07:45 AM
91redteg's Avatar
compression start that ****
Old Jul 1, 2007 | 01:21 PM
It does crank? Or no?? If it doesn't crank, then you can pretty much eliminate the possibility of it being the ECU.
Old Jul 1, 2007 | 06:02 PM
spgcuantik's Avatar
ya it cranks
Old Jul 1, 2007 | 09:12 PM
Did you check the fuel flow like I suggested?? If you've got fuel...then you need to check if you've got spark. Take a spark plug out, and hook it to the spark plug wire, and hold the plug next to the head or block...within a couple centimeters. It should jump a spark from the plug to the block if you've got spark. :et me know what happens.
Old Jul 2, 2007 | 03:12 PM
spgcuantik's Avatar
well there is spark i did exactly wut you told me to do, and yes we took off the return line on the fuel pressure regulator and still no gas
Old Jul 2, 2007 | 08:51 PM
No gas? Sounds like fuel pump to me...or a completely clogged fuel filter. I would look into that first, before assuming its the ECU.
Old Jul 3, 2007 | 01:38 AM
SlammedAccord96's Avatar
Default Re: (loudassVTEC)
Yeah check the wires going into the fuel pump, but check them right at the pump. I think 12V+ at the pump is yellow/green (don't quote me on that, I left my service manual at the shop so I can't confirm it). If it has pos and neg. going into it (I doubt it) then you need a pump. If it doesn't, then go to the main relay and start testing wires...I forget which wire is the "signal" wire from the ECU (it's the one people put a kill switch on - look up a kill switch howto on a teg) and see if that has 12V+. If it does, then it's not getting through the relay (but you said its a new relay so I doubt thats it). If it has no 12V+ then it could be your ECU...just start tracing! Its a pain but luckily you've narrowed down the problem. Good luck!
Old Jul 3, 2007 | 12:36 PM
Default Re: (SlammedAccord96)
Only problem with testing voltage at the pump, is that you have to drop the tank on a DA. its not like the DC or EG.
Old Jul 6, 2007 | 11:29 PM
spgcuantik's Avatar
ok got it started, it was the ecu thx guys for all ur help
delslo94b16a
Dec 30, 2010 07:18 AM
Origin
Dec 19, 2008 10:45 AM
oakpwr
Jan 20, 2007 12:05 PM
jhr1969
Jun 5, 2005 04:00 PM
KenBen
Jun 21, 2004 10:59 AM
