((DA OVERHEATING))
Old Nov 26, 2006 | 01:26 PM
in10ceCiviC's Avatar
Default ((DA OVERHEATING))
i changed the thermostat about 1 month ago and the thing has been running great.....today i was at McDondalds drive thru and i notice that the temp gauge was a little bit past the halfway mark, as i stayed in the line for a long time the temp gauge was going up slowly , then as i drove away the temp gauge was going back to the normal tempature,then when i stopped again it starting getting hot again ? what could this be? the radiator cap?
thanks for reading~!!
Old Nov 26, 2006 | 01:28 PM
prdsmracer03's Avatar
Default Re: ((DA OVERHEATING)) (in10ceCiviC)
Doyou see any leaks, are ur fans kicking on? and check the coolant level...
LJ
Old Nov 26, 2006 | 01:37 PM
Default Re: ((DA OVERHEATING)) (prdsmracer03)
k i just went outside to go check ,
i think its the fan not fkn going on dammit~!!..............
now what?
the thing is running at half temp and the fan isnt turning on ......
Old Nov 26, 2006 | 01:50 PM
gotJDM-DAteg's Avatar
If the fans not working than looks like you need to buy a new fan motor or the whole shabang.
Old Nov 26, 2006 | 02:33 PM
Default Re: ((DA OVERHEATING)) (gotJDM-DAteg)
my friend said it might jus be the relay ? how do i check the relay?
and where is it? is it the one on top of the radiator w/ the two wire because i think the other end is going to the motor?
if its the motor and not the relay can i use a motor from a civic radiator or somthing?
Old Nov 26, 2006 | 02:35 PM
DB1_559's Avatar
i say waterpump mine was doing that than pulled waterpump out and fould blades was all rusted out
Old Nov 26, 2006 | 04:33 PM
b18cda6's Avatar
Default Re: ((DA OVERHEATING)) (jdmboi86)
da integra's have a mysterious fan problem, sometimes they work, sometimes they dont... i remedied the problem by running a toggle switch and running my fans all the time after the car warms up...
probly not the answer your looking for, but just an FYI....
Old Nov 27, 2006 | 01:29 PM
Default Re: ((DA OVERHEATING)) (b18cda6)
ok i know for sure its not the waterpump................it know its the fan because the thing aint coming on when it reaches normal temp.
i ran the fan to the battery to see if the motor blew and the fan turned on ...
so now i know its the RELAY .....................
thanks alot guys i appreciate the help~
Old Nov 27, 2006 | 01:37 PM
int3gra07's Avatar
* B A N N E D *
I was going to say thermostat. But I see you changed it.
Old Nov 27, 2006 | 02:12 PM
freakin_eLRoD's Avatar
i haven't had my DA for long , but if its like most honda's there should be a thermo switch (should be on the thermostat housing) which tells the fan when to come on at a certain temp.
redacura
Acura TL, RL & ZDX
Feb 22, 2007 06:34 PM
brandond
Nov 6, 2005 02:59 PM
SpoonIntegra808
Oct 15, 2004 09:52 AM
b20_ed
Jun 20, 2003 03:33 PM
