DA LS/VTEC question
Old May 25, 2008 | 12:59 AM
McNerny's Avatar
Default DA LS/VTEC question
I have a 93 Integra with a B16A in it right now. I was thinking of buying a B18a block and doing an LS/VTEC. Besides the new oil line, is there anything extra I would have to do to get this going?
Old May 25, 2008 | 02:28 AM
mr.beeks's Avatar
Default Re: DA LS/VTEC question (McNerny)
all you need is that u good to go
Old May 25, 2008 | 07:15 AM
OldSkoolDa91's Avatar
Default Re: DA LS/VTEC question (mr.beeks)
uh, no, that is not it....you need the conversion kit (golden eagle makes a good kit for a good price). just go to the top of this site and search...you will find everything you need to know
Old May 25, 2008 | 07:43 AM
be18see1's Avatar
http://www.g2ic.com/tegtips/engine/15.html
Old May 25, 2008 | 11:55 AM
McNerny's Avatar
Default Re: DA LS/VTEC question (be18see1)
Should I use the oil pump and water pump off of the B16 then? And will the power steering and A/C all be used from the LS?
Old May 25, 2008 | 12:51 PM
Brice.Hayden's Avatar
vtec oil pumps are all the same, water pump, i'm not sure which you should use.
Old May 26, 2008 | 11:04 AM
McNerny's Avatar
Default Re: DA LS/VTEC question (Brice.Hayden)
anyone know if the b16 water pump will work?
Old May 27, 2008 | 04:51 AM
be18see1's Avatar
probably would work. ive seen people use the itr and gsr pump, both of which i presume to be the same. just make sure it has 22 teeth on the gear.
stevenDAtegra
Dec 15, 2008 07:53 AM
airmaxbri
Jun 3, 2008 11:49 AM
D0-Kid
Oct 18, 2007 02:29 PM
Jeanious
Aug 3, 2007 09:09 AM
bens_redeg
Jul 10, 2004 07:11 AM
