da integra help
Old Jan 11, 2008 | 09:30 AM
slix_eg_'s Avatar
Default da integra help
ok i got a 91 integra and just recently started knocking pretty bad... they say i have a spun rod bearing.. like i turn it on it idles good and around 2000rpm it starts knocking can anyone help me? and if it is a sun rod you know the steps on how to fix it ..thanx..
Old Jan 11, 2008 | 09:37 AM
HONDRETTI's Avatar
Default Re: da integra help (slix_eg_)
if you spun a bearing it prolly sounds like theres someone banging a sledgehammer under your hood, you'll at the very least need to have it balanced and polished out. you could probably find another stock crank out or you could even use a different crank for different stroke ratio's. As for the head it's probably ok if it just spun a rod bearing... unless something else came apart....
Peter Brady onlyonweekndz
Nov 2, 2007 09:05 AM
Riceboy891
Aug 4, 2005 05:11 AM
hatchedzex
Oct 13, 2004 03:01 PM
hatchedzex
Oct 4, 2004 11:40 AM
hksbigboi4
Apr 16, 2004 07:48 AM
