Cylinder position sensor
Old Aug 29, 2004 | 01:36 PM
dashway's Avatar
Default Cylinder position sensor
so yesterday i started the teg ..im like WTF!!..code reads 9 (no 1 cylinder position sensor) after some searching i find out this is in the dizzy so i opened it up today and found a few small copper filings that ive read about.
N e one knows what could have caused this i know i have to replace the distributor but it will be a while before i can source one.....(parts are hard to get down here have to import) still starts fine and drives ok.. question is is it safe to drive ie it wont quit on me at some point?
TIA
BTW its a 91 integra XSI
Modified by dashway at 7:21 PM 8/31/2004
Old Aug 30, 2004 | 10:09 AM
dashway's Avatar
Default Re: Cylinder position sensor (dashway)
TTT
Old Aug 30, 2004 | 12:02 PM
JimBlake's Avatar
The distributor shaft bearing is falling apart. Metal dust gets in where those sensors are & messes 'em up.
Clean out the inside of the distributor, especially around the magnetic sensors that read the toothed wheels. Maybe work some lubrication into the shaft bearing??
At this point nobody can promise how long it'll last. You gotta guess that for yourself. Don't waste too much time before ordering it.
Old Aug 30, 2004 | 12:11 PM
Jintegra99's Avatar
Default Re: Cylinder position sensor (JimBlake)
had the same problem not too long ago. eventually the distributor caused a grip of performance-related issues, though you may not experience any yet. my advice: get a new one asap. if it helps, i bought mine from DistributorKing.com , for a pretty good price and have been satisified with it thus far.
tekstyle's Avatar
i am throwing the same code. the car drives fine. according to the helms, it said to replace the ICM (ignition control module). i ran all the tests too and it lead to that. didn't mention anything about replacing the whole distributor.
Old Aug 30, 2004 | 12:25 PM
JimBlake's Avatar
Default Re: Cylinder position sensor (tekstyle)
So yours was the ICM, but he said there's metal filings in there. That sure sounds like the distributor shaft bearing. But I can't be sure without seeing it firsthand.
Old Aug 31, 2004 | 10:21 AM
dashway's Avatar
can it screw up anything else from driving this way??
Old Aug 31, 2004 | 10:42 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dashway &raquo;</TD></TR><TR><TD CLASS="quote">can it screw up anything else from driving this way??</TD></TR></TABLE>Sure. I just don't know how fast...
I'd clean the metal filings out of there & order a new distributor. Like yesterday. If you have to use it for short trips, open up the distributor again & see how quickly it fills up with NEW metal shavings. I guess I'd be afraid to trust it for long trips. If you're really stuck without a local source for a distributor, you're on borrowed time.
Old Sep 1, 2004 | 08:49 PM
Green Lude 93's Avatar
i have the same check light on my teg.
can anyone tell me if its because im running an obd2 distributor with a p28 ecu? or is it just a bad distributor?
Old Nov 4, 2004 | 07:34 AM
Rod.'s Avatar
Default Re: (Green Lude 93)
bump
96GS-R-Kaden
May 21, 2008 12:08 PM
Eparr
Jul 16, 2004 01:49 PM
blufke
Apr 6, 2003 05:10 PM
TheSaianITR
Jan 17, 2003 04:24 PM
