cutting the bump stop
here's a link to a pic of bumpstops off my teg after i lowered her.. (you might have to copy and paste the link)
http://www.geocities.com/sonicblueteg/squirrelstop1.JPG
ya not much left of they ey.. i have like one notch on my teg.. they're hard foam.. remind me of my mom's homemade biscuits.. can't eat them..
the bumpstop sits between the shock and the top of the shock.. it can travel like a bead on a string.. it also helps to slightly cushion impact if you bottom out..
what springs do you have? H&R specifies to not cut the bumpstops when using their Sport Springs. The manufacturer of your springs should tell you how much to cut off, if any,
When you purchase your spring (if new), they should come with a sheet that tells you how much of the bumpstop to trim off on each vehicle. Well, at least Eibach provides this paper. You have to trim the bump stop accordingly inorder to get a good ride, if they are not trim, you can expect a harsh/bumpy ride.
