CTR TB
Old Dec 25, 2001 | 08:01 AM
teg92's Avatar
Default CTR TB
I'm going to be building my LS head in the spring and I'm wondering what you'd think of using a CTR TB instead of a overbored LS TB or stock TB. I believe it's 3mm larger, but not too sure. Thanks!
Old Dec 25, 2001 | 09:04 AM
non-VTEC's Avatar
Default Re: CTR TB (teg92)
i'm pretty sure all B-series throttle bodies are 60mm stock. the ITR uses a 62mm bore stock.
i would think the CTR might use the same size as the ITR......probably 62mm as well..........you can have the stock LS T/B bored out to 64mm easily and it would probably cost less to do as well.......
Old Dec 25, 2001 | 09:35 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: CTR TB (non-VTEC)
Yep, I had my LS done to 64mm by RC engineering. Bought it through http://www.nrg-racing.com
Cost $225 + my core t-body.
Old Dec 25, 2001 | 04:24 PM
teg92's Avatar
Default Re: CTR TB (B18C-EJ1)
Seems pretty pricey... I think I'll wait till the head is built and decide at that point if I want to drop the cash on the TB. Thanks!
Old Dec 25, 2001 | 08:03 PM
TypeR0149's Avatar
get a erics racing throtle body, there the best
Old Dec 26, 2001 | 09:25 AM
Jackson's Avatar
Default Re: CTR TB (Vegeta)
i have heard ctr and si throttlebodies are the same. i have never measured them so dont take my word, but i think you are better off with your ported ls tb.
Old Dec 26, 2001 | 03:26 PM
1fastGSR's Avatar
New User
LS TB 58 mm
Old Dec 26, 2001 | 09:28 PM
ahcjar103's Avatar
Default Re: CTR TB (1fastGSR)
ls tb's and first gen b16 tb's are 58 mm. all other b-series tb's are 60. except R's, which come in at 62
xEnderx
Feb 2, 2006 06:51 PM
untitled
Feb 2, 2005 04:08 PM
ej1times
16
Apr 18, 2004 12:48 AM
ITR1071
May 20, 2002 10:40 AM
C4wrx
Apr 15, 2002 05:00 AM
