ctr cams
Old May 3, 2003 | 09:51 PM
riceball777's Avatar
Default ctr cams
i just picked up some ctr cams yesterday for 300 bucks. my b16 is preatty much stock. this is preatty much going to be my first mod besides my intake. i was going to get a header but i figures i could get the cams for the same price and they probably would make more hp than a header would so i got the cams instead of the header.
i'm going to have them installed tomorrow. i was wondering if i sould get some cam gears. would it help my cams a lot if i had some cam gears
how much faster should these cams make me? should i be able to keep up with gsr's now?
also what about my vtec cross over?
my vtec kicks in very early. it kicks in just above 4000. will that be a problem for the ctr cams?
Modified by riceball777 at 7:02 AM 5/4/2003
Modified by riceball777 at 7:04 AM 5/4/2003
Old May 3, 2003 | 09:55 PM
TegLover4life
Guest
Posts: n/a
Default Re: ctr cams (riceball777)
no, and you need more mods for them to help
Old May 3, 2003 | 09:57 PM
tilt's Avatar
you should get gears, the intake needs to be advanced and the exhaust prob pulled back. ive seen dynos anywhere from ~5-12hp gains. you should change the vtec crossover or else it will dip in power.
Old May 3, 2003 | 10:01 PM
neo1z's Avatar
Default Re: ctr cams (tilt)
I mean itll be better yea...but to really get the power youll need h/e/im/gears etc...
You really dont need gears now...bc I assume youre not getting it tuned anytime soon at all.
Old May 4, 2003 | 09:05 AM
AWD: Jeff's Avatar
well i have ctr in my car right now, n imo if ur planning to get it tune i say buy the cam gears right now so you wont have the hastle to takk out the cams and put cam gears on them. i notice a difference when i got them installed.
Old May 4, 2003 | 10:14 AM
WiggiE's Avatar
New User
Default Re: ctr cams (Dohc93hatch)
The easiest thing you could do, is put on a Skunk2 mani and ITR ECU with the CTR cams.
Old May 4, 2003 | 11:43 AM
95GSRVtec
Guest
Posts: n/a
Im not no DYNO expert but that low vtec point with those cams will not give you the performance you are looking for!! My suggestion is to bump it up to about 5400 till you get it tuned!! And dude why didnt you get cam gears???
Old May 4, 2003 | 12:11 PM
AWD: Jeff's Avatar
Default Re: (95GSRVtec)
yia, from my experience with these ctr's vtec is set to low, and i can feel a difference of how much slugish it feels,
Old May 4, 2003 | 12:15 PM
95GSRVtec
Guest
Posts: n/a
Default Re: (Dohc93hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dohc93hatch &raquo;</TD></TR><TR><TD CLASS="quote">yia, from my experience with these ctr's vtec is set to low, and i can feel a difference of how much slugish it feels,</TD></TR></TABLE>
Ahhh.....Dude i just said the same thing in the post above yours?? Atleast mine made more sense!!
Old May 4, 2003 | 04:38 PM
2fstGSR's Avatar
my car picked up 21 whp in the midrange with the proper tuning using CTR cams. VTEC is set at 5300 rpm.
Old May 4, 2003 | 04:58 PM
rodrez.'s Avatar
[QUOTE=riceball777]i just picked up some ctr cams yesterday for 300 bucks. my b16 is preatty much stock. this is preatty much going to be my first mod besides my intake. i was going to get a header but i figures i could get the cams for the same price and they probably would make more hp than a header would so i got the cams instead of the header.
my vtec kicks in very early. it kicks in just above 4000. will that be a problem for the ctr camsQUOTE]
Does your vtec crossover just over 4k because of the ECU, or a vtec controller? If you don't have a controller, you're going to se a loss of power in the midrange, and it probably won't pick up until about 5800-6k. Might want to hold off on installing them until you get more parts to back them up. Cam gears, FPR, and vtec controller would be good parts to start with. Although you could get by with just the controller.
Old May 4, 2003 | 06:44 PM
AWD: Jeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRVtec &raquo;</TD></TR><TR><TD CLASS="quote">
Ahhh.....Dude i just said the same thing in the post above yours?? Atleast mine made more sense!!</TD></TR></TABLE>
alot of people here give oppinions they hear from others, this is my personal experience and not from what i heard, im just giving him real hard evidence
Old May 4, 2003 | 07:32 PM
Default Re: ctr cams (rodrez)
Does your vtec crossover just over 4k because of the ECU, or a vtec controller? If you don't have a controller, you're going to se a loss of power in the midrange, and it probably won't pick up until about 5800-6k. Might want to hold off on installing them until you get more parts to back them up. Cam gears, FPR, and vtec controller would be good parts to start with. Although you could get by with just the controller. [/QUOTE]
its the ecu i dont have a vtec controler
Old May 4, 2003 | 09:17 PM
rodrez.'s Avatar
[/QUOTE]
its the ecu i dont have a vtec controler[/QUOTE]
Then you should probably hold off on the cams, it's not going to run very smooth
Old May 5, 2003 | 05:21 PM
2fstGSR's Avatar
do not get a FPR!! it is NOT necessary people!!
Old May 5, 2003 | 08:43 PM
rodrez.'s Avatar
Default Re: ctr cams (2fstGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fstGSR &raquo;</TD></TR><TR><TD CLASS="quote">do not get a FPR!! it is NOT necessary people!!</TD></TR></TABLE>
I'd have to disagree. When dyno'ing a motor that's using stock injectors, an FPR can be used to bring up the fuel pressure, while using the VAFC to lean it out where it needs to be, in order to get a smooth power curve.
slowem1si
11
Nov 6, 2005 04:25 PM
andyboy
Jul 21, 2004 06:37 PM
pr0honda
May 19, 2004 03:02 PM
riceball777
May 5, 2003 03:50 PM
StinkyTofu
Jan 4, 2002 09:35 AM
